You're Absolutely right I totally forgot that with a multimeter you measure RMS instead of Peak!!!AC voltage is usually labeled as its RMS value. The peak value is RMS times the square root of 2, or 1.414. 30 radical 2 = 42.426 volts peak. From that you subtract the diode loss and you will have the voltage that will accumulate on your first capacitor if there is no load.
