Actual power consumption of Raspberry Pi Zero 2 W
Kodai
Joined Jan 3, 2025
7
I am a beginner about electronic circuits and english
I am designing a circuit to use two three-terminal regulators L78S05CV (5V2A) to cover the power supply of Raspberry Pi Zero 2 W, because 5V 2.5A is recommended.
However, many sources say that the maximum measured current consumption of the RPi Zero2W is about 5V0.6A.
https://picockpit.com/raspberry-pi/...i-zero-2-w/#Raspberry_Pi_Zero_2_W_power_usage
Does the difference between the catalog specs and the actual measured current mean that it is just a safety margin?
I am producing a work for myself, so I am not looking for excessively high reliability
Due to the size of the board, I interpret the maximum current consumption as 5V0.8A and would like to use other components.
Thank you
Ya’akov
Joined Jan 27, 2019
10,370
Welcome to AAC.
My understanding of the current rating for the RPi Zero 2 W is that its basis is the maximum safe current draw by the board and its connected peripherals. So, rather than being a requirement for operation, it is a maximum possible rating before damage and so also represents the maximum practical supply requirement.
If you are not bus-powering peripherals then the number isn't the one you want. I would suggest empirical measurement of your own configuration, but do be careful to measure startup currents which can be much higher than steady state running. You might find a voltage supervisor useful to ensure a stable boot.
Kodai
Joined Jan 3, 2025
7
Thanks for the answer.
I had forgotten about USB bus power.
I will design the power supply circuit while actually watching the current consumption during startup!
