Bordodynov
- Joined May 20, 2015
- 3,431
Thanks for the comments. You are right and in fact I started to look for other Power FET transistor to better fit my needs for Id/Vds.The DC safe operating area of that FET allows about 55 volts drain to source with a current of 1 ampere. That is a power dissipation of 55 watts, which means it will require a large heatsink to cool it sufficiently and limit your maximum VDD to about 65 V depending on exactly how it performs as a source follower. With a supply voltage any higher than that, the FET is unsuitable for continuous current of 1 ampere. See Figure 3 of the datasheet.
1 A with 140 VDD, it it were permissible, would result in around 130 W of dissipation in the FET which would require a very large heatsink or a lot of air flow over a smaller one and make the thermal interface between the package and the heatskink extremely critical.
This complete DCDC converter with external fets looks to me really great!
Hi Audioguru, please read this post with more accuracy... already saw the picture, thanks to epb, and already answered to it in previous post...Andrea, please post a video of your Mosfet burning and smoking.
Here is the graph from the datasheet with my explanation:
How are you getting 12 V at 1 A from those curves? I read it as between 50 and 60 V. Or 10 mA, since that's a decade below the bottom of the graph?Andrea, please post a video of your Mosfet burning and smoking.
Epa, does no matter, looks anyway this is out of my needs. I probably found some on Vishay sum85n15. It looks can fit 150V@1AHow are you getting 12 V at 1 A from those curves? I read it as between 50 and 60 V. Or 10 mA, since that's a decade below the bottom of the graph?
Epb, sorry....Epa, does no matter, looks anyway this is out of my needs. I probably found some on Vishay sum85n15. It looks can fit 150V@1A
Comments really appreciated. ThanksHi Andrea,
There are a couple of additions I suggest you consider.
Fit a 5Amp fuse in the Drain circuit wiring.
Add a 10K resistor is series with the Gate voltage and connect the Gate to 0V via TVS capable of carrying 5Amps.
If the MOSFET fails without this protection it could take out the Gate driving circuitry.
Finally a reminder, a voltage over 50V can give a shock that can kill.
E
Need to supply a datalog I designed (12V) from a real train battery package (72V in Europe and 110V in Australia with some voltage peak up to 155V)hi Andrea,
Could you tell us exactly why it is required to generate 12Vdc 1A from the high voltage DC source.?
How is it going to be used.?
We maybe able to suggest simpler/safer alternatives in generating the 12V @1A from the 40/160Vdc supply.
E
Here are my additional libraries:This complete DCDC converter with external fets looks to me really great!
I tried to download models to run your simulation but some are missing and/or not running into LTS environment.
It will be possible for you to send me all models you used in the testbench?
Thank you ivery much!
