Power Input Advice
James 26
Joined Mar 26, 2020
10
Hello all,
I have a Zebra TLP 2824 + Label printer that I would like to run of a battery. The unit is currently powered by a 20v DC power adapter. My question is if I use a 18V battery to power the unit will the 10% decrease in voltage damage the unit.
Your input and thoughts appreciated.
James
27,506
How much current does the printer require? And will the battery be able to supply that much current for enough time. Those are the questions.
My guess is that the printer will probably work, but not at the desired performance as the battery drains. But I do not think the printer would be damaged, UNLESS the polarity becomes reversed.
James 26
Joined Mar 26, 2020
10
Yeah you were right printer operated but the print quality is poor due to insufficient current supply for thermal transfer operation to work effectively. Prints are smuged. Was worth a try.
