Power dissipation of synchrononous buck converter cannot be reduced with gate drivers?
kwoki
Joined Aug 31, 2018
12
Hi guys,
For this project, I had to want to reduce the power dissipation (< 2 mW) when the Rload is 54 Ω. These are the two circuits that I have employed.
When I sweep the pwm frequency vs Pdiss (power dissipation of the buck converter), without/with the gate driver, I have the following:
From those two plots with out gate drivers, I see that including gate drivers I increase the power dissipation by increasing switching frequency, but when excluding gate drivers, the power dissipation will decrease with increasing switching frequency. Hence, why is that?
Furthermore, is there a solution to solve this? Maybe decreasing the gate driver area?
The output voltage of the synchronous buck converter is 1.2 V and all other parameters are the same in both the circuits.
kwoki
Joined Aug 31, 2018
12
Thank you for your answer.
the input voltage is 3.6 V from a battery for example.
The output current is 20 mA.
The link that you have shared with me is a pcb component. However, the goal is to design this circuit on a integrated circuit level in 180 nm technology using cadence rather than taking the DC-DC converter PCB component.
drjohsmith
Joined Dec 13, 2021
1,657
OK, sorry it was not obvious you were looking for an ASIC level design,
a simple LDO would drop what power ?
