LTspice How to view the RMS value of waveform for power dissipation in Waveform Viewer.
Stoyan.Nikolov.2Induction
Joined Nov 26, 2023
44
Hi.
LTspice v.17.0.36.0
I am able to view RMS value for Voltage and Current
Waveform separately by simply
Ctrl+LeftMouseClick on the
label of the waveform.
But when Press Ctrl+LeftMouseClick on the
label
of the Waveform of Power
dissipation (Obtained using Alt+Left Click over component) I can View only
Average and Integral Values.
Thank You.
38,425
The average of Instantaneous of real power in case of a sinewave voltage and Capacitor or Inductor is 0 , which is not true for RMS value
RMS power is the power dissipated.
An ideal capacitor or inductor dissipates no real power, so the power is all reactive and the real power value is zero.
Why do you think it's not?
Joined Nov 26, 2023
44
In Ltspice
In circuit consisting of AC Sinewave Voltage 50Hz an pure Inductor (with negligible series resistance)
When I Press Alt+LeftMouseClickKey on Inductor to view its power dissipation
and then Ctrl+LeftMouseClick on the label of the Power in Waveform Viewer it shows values for
-Average
-Integral
That are negligible or almost zero.
That is not the case with RMS Power.
How to plot and see RMS Power?
Joined Nov 26, 2023
44
How to plot and see RMS Value?
Although it is zero in case of pure Inductor.
Not
Average
Integral
I want to see
Average
RMS
The same as with the waveforms of Voltage and Current.
Joined Nov 26, 2023
44
In case of circuit with
50Hz AC Sinewave Voltage Source
and
Pure Inductor
When I Press alt+mouseleftclick on inductor
I have v*i Waveform in Waveform viewer.
When I ctrl+LeftMouseClick on the label of that waveform
v*i
I have
interval start
interval end
Average
Integral
When I Press ctrl+LeftMouseClick on the label of Voltage only waveform
I have
interval start
interval end
Average
Rms
of the voltage only waveform
How to view
RMS of the v*I waveform
like
interval start
interval end
Average
Rms
not
Interval start
interval end
Average
Integral
Joined Nov 26, 2023
44
Alt+LeftMouseClickKey over inductor
gives for Power
Selecting voltage across Inductor gives
Need to view RMS of
V(N001,N002)*I(L1)
Waveform
not only for V(N002,N001) Waveform
38,425
I want to see
Average
RMS
What is your definition of RMS for the power?
The average RMS value of the voltage and the current are indeed non-zero, but the average (RMS) power of the inductor is zero, and that's what the simulation is showing, so what do you think you should see?
38,425
This is what he asked, this is what I posted, no mention, no mention of power in my post.
Okay, I just didn't understand why you would post an equation that has no useful technical meaning.
It seems apparent, that he doesn't understand the meaning of RMS when it comes to power.
ericgibbs
Joined Jan 29, 2010
21,421
I would say my post signature note best explains it, I am trying to understand the way he understands it and what he is really asking
You asked him and got no answer.
He has posted the same question in post #17.
eetech00
Joined Jun 8, 2013
4,704
Hi.
LTspice v.17.0.36.0
label
Thank You.
You have to use .meas statements then view the results in the output log:
