Power board short? LCD TV Hisense 50H5G
KN4RUI
Joined Apr 3, 2019
6
Variac shows regular pulses of over current on power up through current limiter lamps.
Looking for short ....power board vs main board. Protection circuit must be activating...
curious, no power on standby pin, (others good) but tv has red light..isn’t stand by voltage always present and needed for status light?
disconnect main board....no short activity ....2A3FA8F1-2AF9-41C7-AC4A-86A5C446B987.jpegdisconnect disconnect t- con board..still short pattern
led strips just repaired no shorts there....all working
caps, mosfets check out on power board less I’m missing something obvious...don’t know where to go here!
KN4RUI
Joined Apr 3, 2019
6
Thank you for your help. I am puzzled by a zero voltage on power supply board stby pin....is this not always present?
AlbertHall
Joined Jun 4, 2014
12,653
It may be that the main board fault - perhaps overcurrent - has been detected by the power board and it has shut down. This is usually reset by a power cycle.
Another question..... I am still perplexed why there is no standby voltage when the TV is on at the S TB Y pin. And in looking at that circuit I removed an optocoupler that showed voltage each way across the cathode/ anode in circuit....but when removed tested good? Does this indicate a short?
