I have been working on a PCB which requires a single connector(port) for input voltages 24V, 5V and needs to accommodate signal lines such as CANH, CANL and couple other GPIOs as well. What would be the best way to accomplish it.
IDC comes under this.If the power supply current is not excessive, my favorite is a standard 0.1" header connector. It could be two rows or one.
The PCB will treated as a compartment and will be connected by the user. So I would like to have a single port connector, that anybody can use. Also, the PCB will have stopped motor drivers, so current consumption will be slightly high too.Is this connector inside a product, where it will be connected by the manufacturer?
Or is it external to the product, and will be connected by the user?
Do you expect the user to have any technical ability?
For the first case, nothing to beat the standard 2.54mm or 3.96mm header, as everyone else has said.
If the user has to connect to it, the D connector is good, because it protects the cables, but does require a user that can solder (I note that CAN is typically connected using a 9-pin D-connector)
If it has to be connected by an electrician, then your only choices are screw terminals and spring terminals. The green plug-in screw terminals are available in sizes that an electrician's screwdriver will fit into!
by Jerry Twomey
