Power Amplifier repair
runtek
Joined Nov 3, 2019
How difficult is to repair a Power amplifier in stereo receiver?
The receiver model is shown in the link below. It's not an actual item I want to repair, but it same model as mine, so can be useful for information purposes:
Stereo Receiver undercover
How reliable is a board-level repair of such type of PCB board?
35,326
Welcome to AAC!
Give AAC Technical Repair a trial.
Your country
Make and model number
Symptoms
History of unit, before and during the failure, such as, original owner vs bought as-is at booth sale etc., smoked when turned on?
bertus
Joined Apr 5, 2008
23,042
Looking at the first picture the unit is a Denon DRA-F109.
I have not yet found a schematic for it.
There is stated the amplifier part is 65 + 65 Watts.
Looking at the PCB, it is likely a class D amplifier.
Bertus
runtek
Joined Nov 3, 2019
I don't have this receiver yet, I'm considering to buy it for repair. From the info I have, the receiver LED flashing red, I assume the output transistors are faulty, and possibly, surrounding components, too.
manual & schematic
bertus
Joined Apr 5, 2008
23,042
As I thought, the output is a Class D.
See the block diagram:
Here is a triubleshooting from the manual that shows the flashing led.
The speed of flashing seems to show different errors:
Bertus
runtek
Joined Nov 3, 2019
Based on Troubleshooting guide, it can be Power Supply fault and many other fault, depending on power LED flashing intervals.
(differs from other Denon model RCD-M40, where red blinking means amplifier circuit malfunction).
In case of Renesas M3030RFGPFP MCU chip failure, replacing it can be a pain, as it have 100-pins..
I should to know Led flashing frequecny, is it 1/4 sec or 1/2 sec
