Bordodynov
- Joined May 20, 2015
- 3,433
Please download your last file in LTspice format (*.asc), which you used for the simulation.
Dear Bordodynov,Please download your last file in LTspice format (*.asc), which you used for the simulation.
Dear Sir,Looks like low frequency ringing in the output filter, it should damp out eventually if you let the simulation run long enough.
Dear Respected Bordodynov,I should have emphasized right away that your filter gives a lot of power loss. You took the easy way (this is bad) and created a filter with resistors on the input. And this is not all bad. You calculated a small time interval. I did the calculation up to 1000 µs and saw that the output power drops quite significantly over time. 1000 µs isn't enough yet.
Generally speaking you need to increase the values of resistors R9 and R10 to 100 - 200 Ohms. And the filter should perform two functions - filtering and impedance transformation. But this is not easy.
Dear DickCappels,I would like to help but @Bordodynov is already on the job and I don't want to interfere with the master.
Dear Sir,Prably the dissatisfaction wind is blowing from the wrong impedance?? Did U checked Z11 and Z22 complex values??
Dear respected DickCappels,I would like to help but @Bordodynov is already on the job and I don't want to interfere with the master.
Edit: Push-pull class E power amplifier with balanced FETs, but only if driven that way.Here i want another question that, our design is most appropriate for which type of the power amplifiers;
(some text removed for clarity)
1. Pus-pull class E power amplifier with balanced FETs.
2. Differential cascode class E power amplifier.
3. Cascode class E power amplifier .
4. Power combining architecture.
5. self bias casecode class E power amplifier.
Thank you very much sir@DickCappels for your kind help.Edit: Push-pull class E power amplifier with balanced FETs, but only if driven that way.
Dear Respected Bordodynov,I changed the scheme a little bit. I increased the supply voltage. Of course, my filter is not very good. Look at this:View attachment 226721View attachment 226722
