I'm trying to design a power amp that meets very specific specifications, but my specialty is more on the software and digital side of things, so I was hoping maybe someone here could give me some pro tips.
What I need to design is an output stage that can supply 10A RMS to a 60ohm load at frequencies between 1Mhz and 30Mhz. I'm using a THS6212 "Differential Broadband PLC Line Driver Amplifier" as the first stage.
I've done some research and I think a push-pull amp using either MOSFETs or IGBT's should be sufficient, with maybe a feedback loop to limit crossover distortion. Problem is, I've never designed one of these before and information about using IGBT's to design power amps seems to be hard to find on the web. I don't even know if what I've chosen is the most appropriate way to solve this.
I don't necessarily need anyone to solve this for me (though that'd be welcome too, lol), I'm more just looking for locations of good information I can use to help me meet the required specs. I could spend days researching this or I could just ask you guys what you think.
Thanks for your help!
