Possible to Split and solder an FFC (FPC?)
AlbertHall
Joined Jun 4, 2014
12,636
Can I split this cable lengthways to make two 8 way cables, and then solder the ends onto the pads that were intended for SOIC16 IC.
Will it fall apart during the split?
Will it melt during soldering?
AlbertHall
Joined Jun 4, 2014
12,636
Thanks, I'm pleased it's not a completely barking idea.
So, would it be a good idea to get some low melting point solder?
Ya’akov
Joined Jan 27, 2019
10,262
I did it with 63/37 which has a relatively low melting point being a eutectic alloy, but I think if I was doing it today I'd try something like: https://www.amazon.com/Solder-Bi57-6-No-Clean-Lead-Free-Temperature/dp/B0195V1QEI/
On the other hand you gain only a few degrees, so I am not sure it beats 63/37 which is easier to get to wet. I suppose I would test.
If you don't have 63/37, you should anyway. I got some really nice Chipquik paste: https://www.amazon.com/gp/product/B0186IM0P0/ which so far I am very pleased with but otherwise I use very fine Kester solder.
