Positive DC Offset Waveform & High-Pass Filter
Baalshillem
Joined Aug 19, 2019
as seen in the attached screenshot, three waveforms are displayed. The red one is basically the blue signal that has gone
though a high-pass filter (cutoff frequency at 5 Hz). It is a Sallen-Key filter whose amplifier is single-supplied, providing a
rail-to-rail of 0-5V. Knowing the HPF will decrease the impact of the DC offset and components up to around 5 Hz, it led to the
generation to some sort of a rectified half-wave. Could it be the result of the lower rail (0V) limitation, thwarting the other half of the wave from
swinging into the negative voltages? Basically, a self-created anomaly.
to3metalcan
Joined Jul 20, 2014
263
Yes, it's definitely because your op amp is incapable of swinging below its lower power supply rail. You need to bias it at 1/2 your positive supply voltage so it swings around the middle of its range and doesn't chop half the wave off.
