Positive and Negative
joebrau
Joined May 21, 2023
Does anyone know why there are these + - two symbols at the two ends of a power source?
Does it mean that one side has a deficiency and the other an excess of electrons?
Irving
Joined Jan 30, 2016
5,195
Exactly so.. the -ve has excess electrons, and they (conceptually) flow round to the +ve - contrary to 'conventional' current flow from + to -. Confusing huh?!
Welcome to AAC btw, :)
KeithWalker
Joined Jul 10, 2017
3,620
"Conventional current" flow (+ to -) was established long before it was recognized that current is a flow of electrons from - to +.
35,202
Not necessarily so. Think of electric current as marbles in a tube.
Electricity is the motion of electrons along a conducting material. Electrons don't move very fast, about 2cm per hour. When one electron moves, another one follows behind to take its place. Hence, no, there is not an excess of electrons in one place and a deficiency in another.
They move because there is an electric field that pushes them along. The positive sign says that that part in the circuit is at a higher potential than the part with the negative sign. This is by convention. It is similar to why England is north of the equator and Australia is to the south. This is simply conventional.
Irving
Joined Jan 30, 2016
5,195
Hmmm, how do you explain the charge on plates of a capacitor - is not the electric field the result of one plate having an excess and the other a deficit?
ElectricSpidey
Joined Dec 2, 2017
3,360
Electricity is the motion of electrons along a conducting material. Electrons don't move very fast, about 2cm per hour. When one electron moves, another one follows behind to take its place. They move because there is an electric field that pushes them along.
Tell that to a battery or capacitor.
The OP was asking about a source not a conductor.
WBahn
Joined Mar 31, 2012
33,247
Basically, but the amount of charge that is separated is miniscule. What it really means is that positive work will done on a positive charge as it moves from the positive terminal through some external path to the negative terminal. Conversely, positive work will also be done on a negative charge as it moves from the negative terminal to the positive terminal.
BobTPH
Joined Jun 5, 2013
11,661
Yes, but he was asking about a power source, not a capacitor. How do you explain a DC generator? Does it have an excess of electrons on the negative terminal?
ElectricSpidey
Joined Dec 2, 2017
3,360
This discussion could go a lot of different directions.
Such as...is a generator actually a power source or is the actual power source what is turning the generator?
But I agree with the idea that there is little or no charge separation at the terminals of a generator,
ElectricSpidey
Joined Dec 2, 2017
3,360
I have a question.
How does positive charge and negative charge get past each other on the way to their respective destinations?
djsfantasi
Joined Apr 11, 2010
9,237
I have a question.
Is that a rhetorical question?
You’ve heard of holes? Whether or not they actually exist, positive is the absence of electrons. There are not two physical “charges” that need pass by each other. Yes, there are protons, but as long as we’re not talking about an atom bomb, I think they pretty much stay put.
WBahn
Joined Mar 31, 2012
33,247
I have a question.
That is where the conversion from some other form of energy to electrical potential energy comes in.
In a typical chemical battery, it is a diffusion process in which positive and/or negatively charged ions diffuse from a region of higher concentration to lower concentration. Conceptually very similar to the diffusion of electrons and holes across a PN junction. As the diffusion action produces a charge separation, that separation produces an electric field that is trying to draw them back where they came from. At some point (almost instantly) an equilibrium is established and the chemical reactions producing the ions stops. As electrons exit the negative terminal and other electrons enter the positive terminal due to the external circuit connected between them, the electric field within the cell diminishes and the chemical reaction once again can produce the ions that then diffuse and reach an equilibrium again.
WBahn
Joined Mar 31, 2012
33,247
I wasn't speaking of battery chemistry, I was talking about these 2 opposite charges getting past each other in a conductor as implied in post #7.
Where was that implied at all? All I stated is the definition of what a voltage difference is. There is NOTHING in that statement that implies that opposite charges are getting past each other in a conductor.
Wendy
Joined Mar 24, 2008
23,857
you will find this site is a great place to ask questions. I am one of those people that believe there are no stupid questions. Do you know what a DVM is?
Jon Chandler
Joined Jun 12, 2008
1,649
Perhaps y'all in your ongoing debate are addressing something well beyond the intent of the question (not that that EVER happens here).
+ (plus) is the positive terminal of the power supply.
– (minus) is the negative terminal of the power supply.
MrAl
Joined Jun 17, 2014
13,815
I have a question.
This is possible but mostly only in theory. The reason for this is just so we can calculate things sometimes. The net algebraic sum is actually what would really 'flow' in a wire.
For example, if you have 3 to the right and 1 to the left, there is a net flow of 2 to the right, or a net flow of -2 to the left.
You can assign signs if you like. If you have 3 to the right and -1 to the left, there is a net flow of 4 to the right, or a net flow of -4 to the left.
