port 16f872 to 16f882, assembly
30,813
There should be very little difference they are almost identical in modules both are 28pin and Picmicro generally keep the pin No's/types the same across a same pin count.
bug13
Joined Feb 13, 2012
2,002
That's good news!
I only have use mplab x, but never use mplab8. To start with, it seems I need 16F882.inc file instead of 16F872.inc, I have searched the whole computer, but I can't find this file.
Do you know where I maybe able to find this 16F882.inc file?
Thanks!
bug13
Joined Feb 13, 2012
2,002
Now I have these error, what is that mean?
This is the line I have the problem:
__config _HS_OSC & _WDT_OFF & _DEBUG_ON & _LVP_OFF & _CPD_OFF & _WRT_OFF & _PWRTE_OFF
Release build of project `C:\Users\zhuhua.MIRACLE\Desktop\CC3A\CC3A-wdf.mcp' started.
Language tool versions: MPASMWIN.exe v5.46, mplink.exe v4.44, mplib.exe v4.44
Tue Mar 15 10:19:15 2016
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F882 "cc3a.asm" /l"cc3a.lst" /e"cc3a.err"
Error[126] C:\USERS\JOE.MIRACLE\DESKTOP\CC3A\CC3A.ASM 32 : Argument out of range (not a valid config register address)
Halting build on first failure as requested.
Release build of project `C:\Users\zhuhua.MIRACLE\Desktop\CC3A\CC3A-wdf.mcp' failed.
Tue Mar 15 10:19:16 2016
BUILD FAILED
absf
Joined Dec 29, 2010
1,968
The 16F882 inc file is in the
"C:\Program Files\Microchip\MPASM Suite" directory of my MPLAB IDE v8.80
Allen
bug13
Joined Feb 13, 2012
2,002
Clean: Done.
BUILD FAILED
It seems to work if I do these.
__config _CONFIG1, _CP_OFF & _HS_OSC & _WDT_OFF & _BOREN_OFF & _DEBUG_OFF & _LVP_OFF & _CPD_OFF & _PWRTE_OFF
__config _CONFIG2, _WRT_OFF
