porject|Build a voltmeter| accuracy in opamp
Saar Boaz
Joined Apr 18, 2017
5
hellow and thank you for reading.
i got project assiment to develop a voltmeter that can mesure voltages in the range of 10mv-10v with 5% accuracy.
i had allready built a design that works in theory, but in the lab things become real.
i will be glad for your apinion if i should drop the case or not.
in one stage of the design i need to :
1. Amplify a really small signal 10 time: (10mv-0.0995v) signal should be amplified to (100mv -0.995v).
2. i need to lower a signal by 10 : (1v-10v) signal should be lowerd to (100mv -1v).
in order to do so im using 741 op amp, the problem is the accuracy of the 741 and the accuracy of the resistor.
i have upload 3 images , each one shows a different signal the should be lowered/amplified .
another file contain the hole design in multisim.
fill free to download/ check my design .
any suggestion would be welcomed.
thank you very mutch saar.
bertus
Joined Apr 5, 2008
22,921
The LM741 is a bad opamp for this.
The offset will give large faults as you have measured in the low input selection.
Better look for an other opamp with better specifications.
Bertus
Saar Boaz
Joined Apr 18, 2017
5
Bertus
can you specify some models you think will be better?
bertus
Joined Apr 5, 2008
22,921
You could ask fo a LT1055 or LT1056, those have an offset of 0.5 mV max, as the LM741 has an offset of 6 mV max.
If you can not get this opamp, you can try to compensate the offset with the circuit in the LM741 datasheet:
Bertus
