Please review my ground and lightning protection, also give some advice
Question 1, can my lightning counter also count lightning came from lightning rod 2 ?
Question 2, is auxiliary ground that bonded to grounding grid is a good idea ?, that use steel rod (building residual material), not standard rod
Question 3, if lightning occurs can lightning surge enter electricity wire ?, if soil was fail to absorbs spike voltage from lightning, is this can happen ?
All Bare Copper Conductor (BC) is made from pure copper, lightning rod 1 is copper bonded, lightning rod 2 is pure copper
Lightning rod 1 and 2 is also pure copper 3/4" 60cm, water table is only 70cm under soil surface, so soil can absorbs lightning current very good, earth resistance is only 0.192 ohm
Lightning arrester used is SPD type T2, and SPD type T3 in special branch circuit
