My problem statement is to design a circuit to convert a triangular input signal of +/- 10 V amplitudes to a square wave output with +/- 13 V amplitudes. The circuit also needs the capability to control the phase of the output signal relative to the input signal in the range of 0 degrees to 90 degrees.
Im stuck on how to approach designing a circuit to allow for a variable phase shift of 0 degrees to 90 degrees. I am using a 10 K ohm potentiometer but dont know how I should pick my Vref or R1 (to get a Vs of 90 degrees) as seen in the picture attached.
[/IMG]
