I am doing a project on automating a hydroponic system to grow tomatoes. I need a TDS sensor to measure Total Dissolved salts. I searched a lot for a sensor but I was not able to find a sensor that satisfies my requirement. I need a sensor that can measure high ppm. But, the sensors are only capable of measuring 1000ppm. Some Handheld TDS meters which give digital output are capable of measuring (0 - 9990 ppm). Is there a way to get the value that shows in digital display on handheld TDS meter to a raspberry pi so that I can trigger a process depending on the value? I am okay with performing any task to make this possible. I am wondering if there is a way to change any wire connections and connecting them to pi which gives the solution. Any suggestions, please??
Some Handheld TDS meters:
amazon
mi
amazon
mi
