The idea behind staging them has nothing to do with power draw, it's because audio equipment shouldn't be turned on in the wrong order, that's a good way to blow out the drivers.Looking at the LM3914 data sheet and the PCB layout, pin-3 is connected to pin-9. This means that the LM3914 is in bar mode. Outputs 1 to 10 will be activated increasingly based on the analog input on pin-5 which is 33% of the rectified AC input.
The triacs are enabling increasing amounts of current in steps of 10 A.
I do not know where the AC input single originates and what kind of equipment is used in a nightclub that needs power that increases in steps of 10 A.
The original unit was to power up a series of 800 watt power amplifiers. Think of 1975-vintage designs with massive transformers and filter caps. Not only do they pull a considerable amount of power in full operation, but the inrush to charge up 2X 30,000uF power supply filter caps is substantial.
I get that there's quite a few things about this design and application that are not in line with more modern ideas about power supplies and so-on, but think of this project as a vintage-type restoration. I'd like to build this device with the type of devices that it was originally designed for. Since it was designed 45 years ago, I guess this equipment could be considered "vintage" by that definition.
