please help me find irradiance of the LED
n1nja
Joined Sep 7, 2023
i have a uv a led with the following specification
optical watt 0.103W
beam angle 15 degrees
distance from surface 2.4cm
also the circle created by my calculation is 0.313 cmsq
is the irradiance 0.103/0.313?
i have attached spectral result test if that helps367509993_126699860508803_7654524359224210584_n.jpg
MrAl
Joined Jun 17, 2014
13,809
optical watt 0.103W
i have attached spectral result test if that helpsView attachment 302298
That's the way i understand it but it's been a long time since i had to do any of this.
The power divided by the area such as in Watts/SquareMeter or Watts/SquareCentimeter, etc.
If you are dealing with an angle and a distance rather than given an actual area, then yes you would have to calculate the area first.
