Please help Identify Signal Tek II Backup Battery
DickCappels
Joined Aug 21, 2008
10,662
It is a pretty good bet that if you slide the battery out of its holder you will see the battery type ("CR2032" or similar) stamped on the battery itself. Can't really do much with just the photos. If you precisely measure the battery's dimensions and voltage we can probably make a guess, but just reading from the markings on the battery would be much better.
