my meter is autorange, i can check in low range. is a cheap Mastech MS8268.That's not good. what quality is your meter again? Are you checking the resistance in the low range, or in K/Meg or Continuity?
If the coil is actually shorted both ways, that means there isn't really a coil, but you'll need a more accurate resistance reading to tell the difference if it is a low resistance coil. The diode is to stop back EMF from coil inductance, which tells me the coil isn't a single turn.
Please make the schematic a bit larger, maybe double size, and label the VReg output pins.
2.2 ohm now in low range 3-4 and 2.6 ohm 1-2
http://www.amazon.com/gp/product/B000JQ4O2U/ref=ox_sc_sfl_title_4?ie=UTF8&psc=1&smid=AMH4W1K8OCGMX[/URL]
i attached the schematic, the output side is done. View attachment pemf3.pdf
