Please help clarifying connections here
MisterBill2
Joined Jan 23, 2018
28,651
One other comment: Over the years, I have learned many times that "NOT EVERYTHING I AM TOLD" is correct! some of it is simply incorrect, and some of it is VERY TOTALLY incorrect.
SOME power connectors do provide "grounding" in their mounts, some do not.
MisterBill2
Joined Jan 23, 2018
28,651
The drawing in post #1 uses the "ground" symbol only twice. Using the white plastic proto-boards for an experimental build, THAT can indeed be rather confusing. REALLY, that should be tagged "COMMON"! On the pproto-boards, the common rows are the two rows towards the longer outside edges. BUT you still need to do a continuity check because many of those proto-boards are broken at the center. So a short jumper lead may be required.
sonohe
Joined Jan 11, 2025
96
I am aware of that. I still did not decide if I will build it on that kind of board or use the dotted board. That's why I wanted to see how the connections go from the triangle ground symbols and the +/-15. I'll need to wire everything myself, without the comfort of having them ready made on a PCB.
MisterBill2
Joined Jan 23, 2018
28,651
The "proto board" method is much easier, but the compromise is that the assembly is temporary, although some projects have been kept and used for many years. A wired and soldered version built on the perforated project board material can last for as long as it is needed.
