PLEASE HELP! Adder ic's
royashley99
Joined Nov 20, 2021
47
im using a 4 bit adder and i would like to know does the A pin get plus or minus by the B pin or is it the other way around. e.g A + B = S A - B = S or
B + A = S B - A = S
Papabravo
Joined Feb 24, 2006
22,105
B + A = S B - A = S
I'm not sure what you are asking. A 4-bit two's complement adder does not use or understand signs. The process is the same regardless of whether A and B are signed or unsigned. If A and B are unsigned then they are in the range [0..15] and the result is as well. the state of the carry out will not affect the 4-bit sum but can be used to affect the next higher order operation. If A and B are signed, then they are in the range [-8..+7]. The result and the carry out can be used to detect the occurrence of an overflow or underflow.
dl324
Joined Mar 30, 2015
18,446
B + A = S B - A = S
I can't understand what you're asking for. An adder can only add.
Is this schoolwork?
