Plane parachute
#12
Swell parachute. I only wish it had reminded him to fill the gas tank. :D
Still, he was lucky he didn't have to be anywhere near Washington D.C.
A government employee was playing with a toy quad-copter today and every channel on my TV is having a terror crisis threat about it tonight.
jpanhalt
Joined Jan 18, 2008
11,087
The Cirrus is one of the new breed of private airplanes that boasts a ballistic parachute for emergencies. Running out of fuel seems about the easiest thing not to do, yet such pilot errors are 5 times more likely than mechanical failures as the cause of crashes (http://www.ghafi.org/download/GA-Analysis.1.pdf ).
In one incident I witnessed, a pilot flying from Louisiana to St Louis asked for priority landing at Spirit of St. Louis airport in the early 1970's. I was #1, but was made to circle. As soon as he landed and the nose of his airplane rose (he was in a Piper Cherokee/Arrow) his engine stopped on the runway and he had to be towed to the ramp. I was flying from ROC and had made a fuel stop in Columbus, even though my airplane had the range in theory to go non-stop. Running out of fuel is capital stupidity in my book. A fuel stop may delay you a little bit, but it has so many other advantages to offset the 15 to 30 minutes it takes.
John
spinnaker
Joined Oct 29, 2009
7,830
According to the pilot, he had plenty of fuel. Apparently fuel was just not getting to the engines.
There was another inter-island crash on the same day where they did run out of fuel.
MikeML
5,444
If he was 253 mi from Maui, that doesn't sound like an inter-island flight. Wonder if he was flying California coast to HI?
GopherT
Joined Nov 23, 2012
8,009
Ok, something is strange here. Strange about the pilots decisions and why he made them.
Cirrus says their plane (SR-22) has a range of 800 miles including reserve at full speed and minimum payload. 40% extra at 2/3 power.
And the distance from LA to Maui is way more...
And, go figure, he ran out of fuel 1000 miles NE of Hawaii.
Am I missing something in how fuel range is calculated at other altitudes or payload?
#12
Ok, something is strange here. he ran out of fuel 1000 miles NE of Hawaii.
post#5 by spinnaker: He did not run out of fuel.
Apparently you can triple the distance on an 800 mile gas tank when flying down hill, as clearly shown by the map in post #9. Unfortunately, 2400 miles was not enough for a 2,490 mile trip. :rolleyes:
spinnaker
Joined Oct 29, 2009
7,830
That was the pilots claim. Not saying it was reality.
JohnInTX
Joined Jun 26, 2012
4,787
From a Honolulu report:
HONOLULU – The pilot of a single engine Cirrus SR-22 aircraft that ran out of fuel is safe after ditching his aircraft 253 miles northeast of Maui, Hawaii Sunday.
At approximately 4:44 p.m. the pilot was able to deploy the aircraft’s airframe parachute system and safely exit the aircraft into a life raft.
Watchstanders at the Coast Guard Joint Rescue Coordination Center Honolulu identified the cruise ship Veendam, en route to Lahaina, Maui, and coordinated the pilot’s ditch near their location.
At 5:21 p.m. the crew of the Veendam rescued the pilot. The pilot was reported to be in good condition. The plane was last observed partially submerged.
Weather conditions at the time of the rescue were seas of 9 to 12 feet and winds of 25 to 28 mph.
The Coast Guard HC-130 Hercules airplane from Air Station Barbers Point assisted the pilot during the process of ditching his aircraft and maintained communications throughout the ditching process. The Hercules crew remained on scene until the pilot was safely aboard the Veendam.
The flight originated in Tracy, California and was destined for Kahului Maui.
At 12:30 p.m. the pilot contacted the Hawaii National Guard and reported his aircraft had approximately three hours of fuel remaining and he would be ditching 230 miles north east of Maui.
Ferry flights have additional fuel tanks temporarily installed in the baggage compartments and/or passenger area. Transfer pumps are used to pump the ferry fuel into the main tanks of the plane where its used normally. If a valve or pump fails, you have problems but at least time to sort them out while burning off the remaining fuel in the mains. Reports say the pilot had enough time to declare an emergency and get things right - including getting close to the cruise ship before ditching. There have been a few other ferry incidents over the years due to the same kind of problem. From a distance, it looks like the pilot did everything right. My guess is that once the rescue was set up, he shut it down and popped the chute. Good job.
#12
Ooh! Complicated math!
A thousand pounds of extra fuel and a 180 pound pilot cuts the range down to 100 miles, but the "payload" weight of fuel is constantly dropping and it is added to the original specification of 820 miles and multiplied by 1.4 for running at 65% throttle.
I could take 5 minutes just to figure out the equation. Maybe that's why pilots have to study piloting. ;)
jpanhalt
Joined Jan 18, 2008
11,087
It at least looked like a tiny plane. Hard to imagine it could could enough fuel for such a long trip.
You can fit accessory tanks (sometimes called ferry tanks) in many aircraft. The Cirrus is quite a small airplane. I son't have a clue as to whether it can be fitted with ferry tanks.
John
GopherT
Joined Nov 23, 2012
8,009
More like, pilots learn how to use little charts prepared by engineers...
..and why engineers study calculus.
MikeML
5,444
I have flown a Cessna 206 (high-wing, single-engine, turbo-normalized) that was ferried from HI to Oakland, CA. A 400 gallon rubber bladder tank is put on the floor (to spread the weight) right at the C.G. A small 24Vdc pump is rigged to transfer fuel from the bladder up into the wing tanks during flight. The aircraft takes off over-gross weight, so a FAA ferry permit is required. Single pilot, life raft aboard.
I was at the Oshkosh fly-in and talked to homebuilder Jon Johanson that flew his RV4 from Brisbane to Oshkosh (twice). His longest leg was from HI to CA.
I worked at HP with Chuck Kingsford Smith, whose father first flew the other way in 1928.
35,246
Sounds like a differential equation. Do pilots have to study calculus?
33,283
One thing that a lot of people overlook is the effort that was put into rescuing this one person out in the middle of the ocean (okay, so "middle" is a bit of a stretch). The FAA notified the Coast Guard and dispatched a C-130 and contacted a cruise ship that threw it's schedule out the window and went to the serve as the rescue ship. This is typical response. A decade or two ago the pilot of a Cessna got disoriented and ended up way out to the east of the East Coast over the Atlantic and the Navy diverted an entire carrier battle group that was within range to intercept him. I don't recall for sure, but I think the pilot ended up landing on the carrier because the captain determined that that posed less of a risk to the pilot than ditching in the sea. I can't find a reference to the event, but I found some sites were a few others commented on (what appears to be) the same story.
You see this all the time. A missing hunter, hiker, skier, elderly person with dementia, whatever and you immediately have search parties that can number into the hundreds with numerous aircraft in support. Most of those searchers are volunteers, but not all of them. Corporations often get into the act, often in a support role by supplying, or at least paying for, food and such to support the searchers and in many cases will send their own aircraft to assist in the search provided they can get a suitably trained pilot (who sometimes has no affiliation with the company and is just a search pilot that doesn't have a plane available (the normal case on a search -- more pilots than planes).
There aren't that many countries that will put forth that kind of effort to save a single individual -- says quite a bit about those countries that will.
