- Joined Jul 18, 2013
- 30,873
The operative word here is current, it is designed to produce an alternating current in its secondary winding which is proportional to the current being measured in its primary.Certainly I could be wrong as so far I have never attempted to construct a current transformer, but my impression is that only 20 turns of #24 wire would produce very little voltage. An "AC Line Current Detector" that I found on the web by Bill (?) Bowden calls for 800 turns or more of #30- #40 wire wound on a1 inch diameter U- bolt.
He writes, "The magnetic pick-up [his coil on a U-bolt] produces about 4 milli-Volts peak for a AC line current of 250 mA."
Regards,
Pete
See the link I mentioned in post #35 for a complete description.
