You have not posted the results of the build... I would suggest you do that so warnings and errors can be ruled out...No error number, just what i attached earlier at the post.
Writes to the configuration word should be monitored closely, with a single bit potentially bricking the device. It is possible you wrote a test that set the code protect bit, in which case, you made yourself a new decoration in the IC graveyard...i will send the build.
but a quick question that may prove a point.
if i want in all memory range to put 1's.
I load MPLAB IPE program, fill memory with 1's and programming should work, but this doesn't work, so my assumption is that the code isn't the problem.
are there critical memory segments that when erasing memory can render the 12f629 useless ?
I was under impression that a bulk erase would fix this problem on a F version PIC. A bulk erase at least under MPLAB. Is done byWrites to the configuration word should be monitored closely, with a single bit potentially bricking the device. It is possible you wrote a test that set the code protect bit, in which case, you made yourself a new decoration in the IC graveyard...
For the newer ones, that should be true, provided I've does a bulk erase... not sure about this one. There are some fringe errors floating about, here's is one person's solution to an odd error.I was under impression that a bulk erase would fix this problem on a F version PIC. A bulk erase at least under MPLAB. Is done by
Toolbar-> programmer -> "Erase flash device"
After this the device under programming must be go through power on cycle. But then the chip should be virginal.
+1, I use these and have never had problems...I doubt the wire gauge was an issue,there just isn't enough current for the gauge to matter.
I always use pins like these to attach the PICkit and I never have connection problems:
They come in 40 pin strips, just snap off as many pins as you need.
| Thread starter | Similar threads | Forum | Replies | Date |
MPLAB® PICkit™ Basic In-Circuit Debugger | Microcontrollers | 2 | |
PIC18f4550 Programming by PICKIT 5 | Microcontrollers | 4 | |
Pickit 3 OK for 12F1822 ? | Microcontrollers | 1 | |
| A | pickit 4 error | Microcontrollers | 3 | |
| M | Write 12f629 pickit 2 or pickit 3 | General Electronics Chat | 10 |
