pickit 4 error
geekoftheweek
Joined Oct 6, 2013
1,429
Why you block out the version information? It's not like someone can do anything with it other than maybe use it for actually helping.
Usually it's one of four things. It's not connected correctly, the PIC itself is faulty, you have selected the wrong part, or your PICKIT is damaged.
Which PIC is it?
atferrari
Joined Jan 6, 2004
5,030
Not sure if this could relate to your secret/mysterious PicKit4 but the "failure" of mine was due to automatic update by Microchip. Pity I learnt that when a free replacement was already in his way to me.
Alex1700
Joined Jan 12, 2020
107
Which PIC is it?
The electronic correction is correct I flashed the firmware successfully many times before the pickit 4 failure after I used the debugging mode the pickit 4 kept popping up failing to get the device id any clue? new picture updated
