Write 12f629 pickit 2 or pickit 3
martijndk1983
Joined Jul 26, 2015
21
Hello Guys,
For my modeltrains I must write several pic's 12f629.
I used Google because this is the first time I am gonna do that but I can't find what I must use.
Many users seems to have problems with the pickit3 and this chips, so should I go better for the pickit2 or 3?because the problems I have read are many years before.
Thanks for the help and when I have it in my house I'll going to ask what next.
With kind regards.
LesJones
Joined Jan 8, 2017
4,544
Either PICKIT2 or PICKIT3 should work. When I first strted using PIC16F629s I used a parallel port programmer baised on the Tait design. I think I have programmed them using bothe PICKIT2 & 3
Les.
martijndk1983
Joined Jul 26, 2015
21
Oke, then I go for an pickit 3 I think with the usb connection.
Can I learn somewhere how I hooked it up.
I have now an ch341a but they would not work with the 12f629.
MaxHeadRoom
Joined Jul 18, 2013
30,813
If using MPLAB-IDE then use Pickit2 for sure, Pickit3 is a pain to use with it.
I program in Assembly so the IDE version seems alot user friendly for this.
Plus you have the Pic stand-alone analyzer/programmer to use.
Max.
martijndk1983
Joined Jul 26, 2015
21
oke, i use a pre configured hex file so i only have to read/write on an easy way.
I think here i found something, but what kind of program software do i need then.
or is a pickit better, i cant find a pickit 2 in the netherlands with a board.
thanks so far.
MaxHeadRoom
Joined Jul 18, 2013
30,813
I am talking about the V2.61 Software in conjunction with a Pickit2 rather than pickit3, which does not run with it.
I got one of the Pickit2 knock-offs, works fine!
Max.
