You don't have it it hooked up right.
Excellent advice. When it comes to working with microcontrollers, there are enough "gotchas" lurking in the weeds without adding even more in the form of an off-brand, knockoff programmer of unknown quality.Or it is because it is a clone.
Buy a real Pickit. Save yourself a headache.
Thank you Spinnaker and OBW
'there are enough "gotchas" lurking in the weeds'
It certainly seems that way with these PIC's.
Well. This cheapskate here just can't bring himself to pay $50 for a Microchip PICKit 3.
Before I would do that I would get a used ICD2 off Ebay for $20.or PICKit 2 for $35.
Mouser actually still has some PICKit 1's ! $36
Just stubborn I guess.
WRONG! Just check the posts here. They are a source of major headaches. They might work They might not. Best to buy a Microchip programmer.There is nothing wrong with having a clone. For the most part most times the pickit don't work has nothing to do with it being real or not real.
Spinnaker
'very skeptical if you could buy a real pickkit 2 for $35'
http://www.ic0nstrux.com/products/programmers-debug/pickit-2-programmer#.Wbqwc2e4fOx
You can take up that subject with Iconstructux.
Thank you Bebe and Spinnaker!
Going to test 10F200 and 12F508 with Low Pin Count board.
Left out something.
Used PICKit 3 clone with Low Pin Count board and 12F1501.
Worked fine.
| Thread starter | Similar threads | Forum | Replies | Date |
MPLAB® PICkit™ Basic In-Circuit Debugger | Microcontrollers | 2 | |
PIC18f4550 Programming by PICKIT 5 | Microcontrollers | 4 | |
Pickit 3 OK for 12F1822 ? | Microcontrollers | 1 | |
| A | pickit 4 error | Microcontrollers | 3 | |
PICKit 2 Clone Reading PIC | Microcontrollers | 6 |
