PIC24FJ, Connecting AVDD causes Target Device ID of 0x0
dannybeckett
Joined Dec 9, 2009
185
Something very strange is happening. I connect AVDD to my micro and it doesn't get recognised by Microchip's IPE. When I disconnect AVDD, the correct Target ID is detected and I get the message "Target device PIC24FJ256GB206 found."
This schematic is correct, as I've prototyped this board before. I've checked all the ground and power pins, and everything seems normal. I've never encountered this behaviour before, does anyone have any suggestion as to why this could be happening? The chip I'm using has been manually de-soldered form a different board, could I have damaged it in a way that causes this error?? Seems strange that it would talk at all if it were irreperably damaged though...
Any help is greatly appreciated!
Dan
22,116
Does the chip have a corresponding AGND pin which is floating? For what is probably the 1,000th time: "Why do you think a verbal description is sufficient to help you solve your problem"? Why TF don't you give us SCHEMATICS, SCHEMATICS, SCHEMATICS!!!
DickCappels
Joined Aug 21, 2008
10,661
Could it be that the power supply voltage for your PIC is higher than the power supply voltage of your IPE, making the logic levels incompatible?
ErnieM
Joined Apr 24, 2011
8,415
Define "prototype." is this a PCB where you are very sure the wiring is the same same or is it hand wired where anything goes?
I try to never reuse desoldered chips, they tend to be troublesome.
