Pic18F47J13 external interrrupt?
spinnaker
Joined Oct 29, 2009
7,830
I have the following coming from my Hall Effect sensor.
When the sensor trips the output goes from rail to zero volts. Do I need to invert the signal before sending it to the external interrupt pin Or can I use on falling edge?
spinnaker
Joined Oct 29, 2009
7,830
It doesn't matter. You program the interrupt pin for either rising edge or falling edge.
You can also detect interrupt-on-change (PORTB), i.e. interrupt on both edges.
Great thanks.! That is what I expected. Just wanted to confirm.
