I have never used capture mode before. I thought this was a way to capture the time difference between two events. But the datasheet says:
Capture Mode
In Capture mode, the CCPR4H:CCPR4L register pair
captures the 16-bit value of the TMR1 or TMR3 register
when an event occurs on the CCP4 pin, RB4. An event
is defined as one of the following:
• Every falling edge
• Every rising edge
• Every 4th rising edge
• Every 16th rising edge
Am I taking this too literally? Is what they are really saying here is the timer registers are updated on the next event with the time from the previous event? Or am I completely off base on the use of capture mode?
Do I need to enable the timer? Is here anything else on the timer I need to configure?
Capture Mode
• Every rising edge
