Hi, everyone
is it possible the PIC16F84A operate at 1V as minimum operating voltage?
huh??
but i test with my PIC
this is show the input pins when there is given to 1 volts, the LEDs that connected at output pins will be light up..
but the pins that i connect is RA0 but still is TTL right?
Means the Logic high for all the input port will be the same as the RA4?
BMorse, I think you have misread the datasheet. It states 0.8 Vdd is required, that means 80% of Vdd. If you supply it even the minimum 2V then 1.6V is the minimum guaranteed logic high.
means is according to the circumference?
because i'm doing with the final report..
The operating voltage of PIC that i wrote is from 1V to 5.5V
i afraid that is unacceptable..
| N | Help Debugging PIC16F84A Code for Dual Tank System | Homework Help | 1 | |
| D | PIC16F84A TIMER0 | Microcontrollers | 8 | |
| D | PIC16F84A to PIC16F877 migration failure. | Microcontrollers | 25 | |
| D | Musical note using PIC16F84A (Assembly code) | Programming & Languages | 5 | |
| J | PIC16F84A with Matrix Keypad. | Microcontrollers | 1 |
