PIC16F84A to PIC16F877 migration failure.
DonutChan
Joined Mar 3, 2019
33
I had my piano program successfully work on PIC16F84A, but when i took the same program with the same wiring to another PIC(Pic16F877) on Proteus, the sound keeps cutting off in an annoying way. I don't know why. Same problem happened after i took it to PIC16F877A. I used assembly code,, some buttons and a speaker, along with their resistors etc.. please help? i tried to look for some hints but nothing seemed to tick.
DonutChan
Joined Mar 3, 2019
33
Post your code?
(i used a program i found on the web, but got a grasp of how it works.)
Code:
  list        p=16f877A
    #include    <p16f877A.inc>
   __CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _RC_OSC & _WRT_OFF & _LVP_ON & _CPD_OFF
    CBLOCK    H'0C'
    CNT
    CNT10
    CNTM
    ENDC
    CLRF    PORTB
    BSF    STATUS,RP0
    CLRF    TRISA
    BCF    OPTION_REG,7
    MOVLW    H'FF'
    MOVWF    TRISB
    BCF    STATUS,RP0
;    KEY
KEY
    BTFSC    PORTB,0        ;KEY ON?
    GOTO    K1        ;KEY OFF
    CALL    DEL10M        ;
    BTFSC    PORTB,0
    GOTO    KEY         ;KEY OFF
    CALL    DO_        ;?h
K1    BTFSC    PORTB,1        ;KEY ON?
    GOTO    K2        ;KEY OFF
    CALL    DEL10M
    BTFSC    PORTB,1
    GOTO    K1
    CALL    RE
K2    BTFSC    PORTB,2        ;KEY ON?
    GOTO    K3        ;KEY OFF
    CALL    DEL10M
    BTFSC    PORTB,2
    GOTO    K2
    CALL    MI
K3    BTFSC    PORTB,3        ;KEY ON?
    GOTO    K4        ;KEY OFF
    CALL    DEL10M
    BTFSC    PORTB,3
    GOTO    K3
    CALL    FA
K4    BTFSC    PORTB,4        ;KEY ON?
    GOTO    K5        ;KEY OFF
    CALL    DEL10M
    BTFSC    PORTB,4
    GOTO    K4
    CALL    SO        ;?\
K5    BTFSC    PORTB,5        ;KEY ON?
    GOTO    K6        ;KEY OFF
    CALL    DEL10M
    BTFSC    PORTB,5
    GOTO    K5
    CALL    RA
K6    BTFSC    PORTB,6        ;KEY ON?
    GOTO    K7        ;KEY OFF
    CALL    DEL10M
    BTFSC    PORTB,6
    GOTO    K6
    CALL    SI
K7    BTFSC    PORTB,7        ;KEY ON?
    GOTO    KEY         ;KEY OFF
    CALL    DEL10M
    BTFSC    PORTB,7
    GOTO    K7
    CALL    DO
    GOTO    KEY
;    10MSEC
DEL10M     MOVLW    10
    MOVWF    CNT10
DLY10    MOVLW    142
    MOVWF    CNTM
DLYU     GOTO    $+1
    GOTO    $+1
    DECFSZ    CNTM,1
    GOTO    DLYU
    DECFSZ    CNT10,1
    GOTO    DLY10
    RETURN
DO_    BSF    PORTA,0
    MOVLW    67
    MOVWF    CNT
    CALL    DLY
    GOTO    $+1
    GOTO    $+1
    NOP
    BCF    PORTA,0
    MOVLW    67
    MOVWF    CNT
    CALL    DLY
    GOTO    $+1
    BTFSS    PORTB,0
    GOTO    DO_
    RETURN
RE    BSF    PORTA,0
    MOVLW    60
    MOVWF    CNT
    CALL    DLY
    GOTO    $+1
    BCF    PORTA,0
    MOVLW    59
    MOVWF    CNT
    CALL    DLY
    GOTO    $+1
    GOTO    $+1
    GOTO    $+1
    BTFSS    PORTB,1
    GOTO    RE
    RETURN
MI    BSF    PORTA,0
    MOVLW    53
    MOVWF    CNT
    CALL    DLY
    GOTO    $+1
    GOTO    $+1
    GOTO    $+1
    NOP
    BCF    PORTA,0
    MOVLW    53
    MOVWF    CNT
    CALL    DLY
    GOTO    $+1
    BTFSS    PORTB,2
    GOTO    MI
    RETURN
FA    BSF    PORTA,0
    MOVLW    50
    MOVWF    CNT
    CALL    DLY
    GOTO    $+1
    GOTO    $+1
    BCF    PORTA,0
    MOVLW    50
    MOVWF    CNT
    CALL    DLY
    NOP
    BTFSS    PORTB,3
    GOTO    FA
    RETURN
SO    BSF    PORTA,0
    MOVLW    45
    MOVWF    CNT
    CALL    DLY
    NOP
    BCF    PORTA,0
    MOVLW    44
    MOVWF    CNT
    CALL    DLY
    GOTO    $+1
    GOTO    $+1
    BTFSS    PORTB,4
    GOTO    SO
    RETURN
RA    BSF    PORTA,0
    MOVLW    40
    MOVWF    CNT
    CALL    DLY
    BCF    PORTA,0
    MOVLW    39
    MOVWF    CNT
    CALL    DLY
    GOTO    $+1
    NOP
    BTFSS    PORTB,5
    GOTO    RA
    RETURN
SI    BSF    PORTA,0
    MOVLW    35
    MOVWF    CNT
    CALL    DLY
    GOTO    $+1
    GOTO    $+1
    BCF    PORTA,0
    MOVLW    35
    MOVWF    CNT
    CALL    DLY
    BTFSS    PORTB,6
    GOTO    SI
    RETURN
DO    BSF    PORTA,0
    MOVLW    33
    MOVWF    CNT
    CALL    DLY
    GOTO    $+1
    NOP
    BCF    PORTA,0
    MOVLW    33
    MOVWF    CNT
    CALL    DLY
    NOP
    BTFSS    PORTB,7
    GOTO    DO
    RETURN
DLY    GOTO    $+1
    GOTO    $+1
    DECFSZ    CNT,1
    GOTO    DLY
    RETURN
;    END
    END
jpanhalt
Joined Jan 18, 2008
11,087
The 16F84A has 2 banks of memory. The 16F877(A) has 4 banks. That is probably where your problem is. There is no way to solve it without your code.
Please use code tags like this: [code=MPASM] <insert code>[/code] and single space if possible.
JohnInTX
Joined Jun 26, 2012
4,719
Any warnings from the assembler?
Also, turn LVP OFF in the CONFIG to be able to use RB3 as an IO input.
DonutChan
Joined Mar 3, 2019
33
i'm relatively aware of that, i just think that there's some kind of register that is on by default, messing with the consistency of the sound? it just keeps buffering ;;;
JohnInTX
Joined Jun 26, 2012
4,719
If you are using an ISCP programmer, RB6 and RB7 will be used by that.
Do you have a PICkit or similar debugger? In that case, RB6 and RB7 are not usable for general IO while debugging.
DonutChan
Joined Mar 3, 2019
33
I don't currently have a programmer with me, i'm just testing it over on Proteus. it doesn't seem to work
JohnInTX
Joined Jun 26, 2012
4,719
Change
DLY10 MOVLW 142
to
DLY10 MOVLW .142
The default radix for the assembler is hex and 142h won't fit into one byte. You should visit the other constants as well or add
radix = dec
at the beginning of the code.
Based on that value, I'm assuming that the original code used decimal as the default radix. Hard to tell with internet code.
If NOT, then you'll have to sort out what the original programmer meant by that line.
DonutChan
Joined Mar 3, 2019
33
Change
DLY10 MOVLW 142
to
DLY10 MOVLW .142
radix = dec
okay, i did what you said, and it definitely improved things, only a little buffering left
JohnInTX
Joined Jun 26, 2012
4,719
I cleaned it up for you. No warnings left and added some comments to help you debug it.
I also added
movlw 06h ; make ALL port pins digital
movwf ADCON1
to make RA0 a digital pin.
Good luck!
Code:
  list  p=16f877A
  radix dec  ; numbers in code imply decimal but check!
  ERRORLEVEL -302  ; suppress cross bank warnings
  __CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _RC_OSC & _WRT_OFF & _LVP_OFF & _CPD_OFF
;***************** RAM  *******************************
  CBLOCK  H'20'
  CNT
  CNT10
  CNTM
  ENDC
  ;***************** START  **************************
  ORG 0
  CLRF  PORTB
  BSF  STATUS,RP0
  CLRF  TRISA
  BCF  OPTION_REG,7
  MOVLW  H'FF'
  MOVWF  TRISB
  movlw  06h  ; make ALL port pins digital!!!
  movwf  ADCON1
  BCF  STATUS,RP0
;  KEY
KEY:
K0:
  BTFSC  PORTB,0  ; KEY ON?
  GOTO  K1  ; no, check next key
  CALL  DEL10M  ; else, its pressed, debounce time..
  BTFSC  PORTB,0  ; then check again
  GOTO  K0  ; KEY OFF, back to top
  CALL  DO_  ; else, key still down Play DO
K1:
  GOTO  K2  ;no, check next key
  CALL  DEL10M  ; debounce delay
  BTFSC  PORTB,1  ; check key again
  GOTO  K1  ; OFF - go back to top of loop
  CALL  RE  ; else, play RE then fall through looking for next key
K2:
  GOTO  K3  ;no
  CALL  DEL10M
  BTFSC  PORTB,2
  GOTO  K2
  CALL  MI  ; play ME
K3:
  GOTO  K4  ;no
  CALL  DEL10M
  BTFSC  PORTB,3
  GOTO  K3
  CALL  FA  ; play FA
K4:
  GOTO  K5
  CALL  DEL10M
  BTFSC  PORTB,4
  GOTO  K4
  CALL  SO  ; play SO
K5:
  GOTO  K6
  CALL  DEL10M
  BTFSC  PORTB,5
  GOTO  K5
  CALL  RA  ; play RA
K6:
  GOTO  K7
  CALL  DEL10M
  BTFSC  PORTB,6
  GOTO  K6
  CALL  SI  ; play SI
K7:
  GOTO  KEY  ; no, loop to top
  CALL  DEL10M
  BTFSC  PORTB,7
  GOTO  K7
  CALL  DO  ; play DO
  GOTO  KEY  ; go to top
;  10MSEC DELAY
DEL10M:
  MOVLW  10
  MOVWF  CNT10
DLY10:
  MOVLW  142
  MOVWF  CNTM
DLYU:
  GOTO  $+1
  GOTO  $+1
  DECFSZ  CNTM,1
  GOTO  DLYU
  DECFSZ  CNT10,F
  GOTO  DLY10
  RETURN
; Play notes
DO_:
  BSF  PORTA,0  ; high 1/2 cycle of note
  MOVLW  67  ; delay
  MOVWF  CNT
  CALL  DLY
  GOTO  $+1
  GOTO  $+1
  NOP
  BCF  PORTA,0  ; low 1/2 cycle of note
  MOVLW  67  ; delay
  MOVWF  CNT
  CALL  DLY
  GOTO  $+1
  BTFSS  PORTB,0 ; check key down each full cycle
  GOTO  DO_  ; play another cycle
  RETURN
RE:
  BSF  PORTA,0
  MOVLW  60
  MOVWF  CNT
  CALL  DLY
  GOTO  $+1
  BCF  PORTA,0
  MOVLW  59
  MOVWF  CNT
  CALL  DLY
  GOTO  $+1
  GOTO  $+1
  GOTO  $+1
  BTFSS  PORTB,1
  GOTO  RE
  RETURN
MI:
  BSF  PORTA,0
  MOVLW  53
  MOVWF  CNT
  CALL  DLY
  GOTO  $+1
  GOTO  $+1
  GOTO  $+1
  NOP
  BCF  PORTA,0
  MOVLW  53
  MOVWF  CNT
  CALL  DLY
  GOTO  $+1
  BTFSS  PORTB,2
  GOTO  MI
  RETURN
FA:
  BSF  PORTA,0
  MOVLW  50
  MOVWF  CNT
  CALL  DLY
  GOTO  $+1
  GOTO  $+1
  BCF  PORTA,0
  MOVLW  50
  MOVWF  CNT
  CALL  DLY
  NOP
  BTFSS  PORTB,3
  GOTO  FA
  RETURN
SO:
  BSF  PORTA,0
  MOVLW  45
  MOVWF  CNT
  CALL  DLY
  NOP
  BCF  PORTA,0
  MOVLW  44
  MOVWF  CNT
  CALL  DLY
  GOTO  $+1
  GOTO  $+1
  BTFSS  PORTB,4
  GOTO  SO
  RETURN
RA:
  BSF  PORTA,0
  MOVLW  40
  MOVWF  CNT
  CALL  DLY
  BCF  PORTA,0
  MOVLW  39
  MOVWF  CNT
  CALL  DLY
  GOTO  $+1
  NOP
  BTFSS  PORTB,5
  GOTO  RA
  RETURN
SI:
  BSF  PORTA,0
  MOVLW  35
  MOVWF  CNT
  CALL  DLY
  GOTO  $+1
  GOTO  $+1
  BCF  PORTA,0
  MOVLW  35
  MOVWF  CNT
  CALL  DLY
  BTFSS  PORTB,6
  GOTO  SI
  RETURN
DO:
  BSF  PORTA,0
  MOVLW  33
  MOVWF  CNT
  CALL  DLY
  GOTO  $+1
  NOP
  BCF  PORTA,0
  MOVLW  33
  MOVWF  CNT
  CALL  DLY
  NOP
  BTFSS  PORTB,7
  GOTO  DO
  RETURN
; Note delay
DLY:
  GOTO  $+1
  GOTO  $+1
  DECFSZ  CNT,F
  GOTO  DLY
  RETURN
  END
