How to use TIMR0 in PIC16F84A using assembly language PLZ I need help
andrew132
Joined Feb 2, 2017
96
hello everyone i need help how to use timer0 in pic using assembly language if i need to make 2 sec delay how to make it when using internal clock 4Mhz
Moderators note : changed title from all capitals to regular text, all capitals are like shouting
andrew132
Joined Feb 2, 2017
96
can anyone write a program using assmebly to make the led on pin A0 flash every 2sec using pic16f84
MaxHeadRoom
Joined Jul 18, 2013
30,808
Pick the bones out of this one!
Max.
Code:
; ZERO-ERROR ONE SECOND TIMER
; (Roman Black 2001, public domain, use it as you like)
; INTERRUPT VERSION
; for PIC 16F84 at 4 MHz (or most PICs)
; (this code has been assembled with MPLAB and hardware tested)
; (for best viewing set TABS=5 in MPLAB editor)
; Note! See text: www.RomanBlack.com/one_sec.htm
; Generates an event every second (or other period) from any PIC
; with any clock frequency.
; This version uses the timer0 overflow interrupt.
; Code can be adapted for different clock speeds, period lengths
; and accuracy levels.
; processor defined ;
   include <p16f84.inc>
; MPLAB stuff here
   LIST b=5, n=97, t=ON, st=OFF
   ; absolute listing tabs=5, lines=97, trim long lines=ON, symbol table=OFF
   __CONFIG  _CP_OFF & _WDT_OFF & _PWRTE_ON & _XT_OSC
   ; config for 16F84; code protect OFF, watchdog OFF, powerup timer ON,
   ; oscillator is XT ready for 4 MHz crystal or resonator.
; Variables here
   CBLOCK 0x20       ; start of ram in 16F84
     bres_hi       ; hi byte of our 24bit variable
     bres_mid       ; mid byte
     bres_lo       ; lo byte
             ; (we only need 3 bytes for this system)
     status_temp     ; used for interrupt servicing
     w_temp       ; used for interrupt servicing
   ENDC
; Code here
   org 0x000        ; Set program memory base at reset vector 0x000
reset
   goto setup       ; set up ints and port stuff
   org 0x004         ; Interrupt vector, int handler code comes next.
;  INTERRUPT HANDLER  (runs this code each timer0 interrupt)
int_handler         ;
             ; first we preserve w and status register
   movwf w_temp       ; save off current W register contents
   movf   STATUS,w     ; move status register into W register
   movwf status_temp     ; save off contents of STATUS register
   ; Note! we get here every 256 instructions, we
   ; can now do our special one second timing system.
   ; This consists of three main steps;
   ; * subtract 256 counts from our 24bit variable
   ; * test if we reached the setpoint
   ; * if so, add 1,000,000 counts to 24bit variable and generate event.
             ; * optimised 24 bit subtract here
             ; This is done with the minimum instructions.
             ; We subtract 256 from the 24bit variable
             ; by just decrementing the mid byte.
   tstf bres_mid       ; first test for mid==0
   skpnz         ; nz = no underflow needed
   decf bres_hi,f       ; z, so is underflow, so dec the msb
   decfsz bres_mid,f     ; dec the mid byte (subtract 256)
             ; now the full 24bit optimised subtract is done!
             ; this is about 4 times faster than a "proper"
             ; 24bit subtract.
   goto int_exit       ; nz, so definitely not one second yet.
             ; in most cases the entire int takes
             ; only 16 instructions.
             ; * test if we have reached one second.
             ; only gets here when mid==0, it MAY be one second.
             ; only gets to here 1 in every 256 times.
             ; (this is our best optimised test)
             ; it gets here when bres_mid ==0.
   tstf bres_hi       ; test hi for zero too
   skpz           ; z = both hi and mid are zero, is one second!
   goto int_exit       ; nz, so not one second yet.
   ; Only gets to here if we have reached one second.
   ; now we can generate our one second event, like add
   ; one second to our clock or whatever.
   ; (in this example we toggle a led)
   ; The other thing we need to do is add 1,000,000 counts
   ; to our 24bit variable and start all over again.
             ; Add the 1,000,000 counts first.
             ; One second = 1,000,000 = 0F 42 40 (in hex)
             ; As we know hi==0 and mid==0 this makes it very fast.
             ; This is an optimised 24bit add, because we can
             ; just load the top two bytes and only need to do
             ; a real add on the bottom byte. This is much quicker
             ; than a "proper" 24bit add.
   movlw 0x0F       ; get msb value
   movwf bres_hi       ; load in msb
   movlw 0x42       ; get mid value
   movwf bres_mid       ; load in mid
   movlw 0x40       ; lsb value to add
   addwf bres_lo,f     ; add it to the remainder already in lsb
   skpnc         ; nc = no overflow, so mid is still ok
   incf bres_mid,f     ; c, so lsb overflowed, so inc mid
             ; this is optimised and relies on mid being known
             ; and that mid won't overflow from one inc.
             ; that's it! Our optimised 24bit add is done,
             ; this is roughly twice as quick as a "proper"
             ; 24bit add.
             ; now we do the "event" that we do every one second.
             ; Note! for this example we toggle a led, which
             ; will give a flashing led which is on for a second
             ; and off for a second.
             ; Add your own code here for your one second event.
             ; Note! My led is on porta,3
             ; your led may be on a different pin.
   movlw b'00001000'     ; mask for bit 3
   xorwf PORTA,f       ; toggle PORTA,bit3 (toggle the led)
   ; now our one second event is all done, we can exit the
   ; interrupt handler.
             ; finally we restore w and status registers.
             ; also clears TMRO int flag now we are finished.
int_exit
   BCF INTCON,T0IF     ; reset the tmr0 interrupt flag
   movf status_temp,w     ; retrieve copy of STATUS register
   movwf STATUS     ; restore pre-isr STATUS register contents
   swapf w_temp,f
   swapf w_temp,w     ; restore pre-isr W register contents
   retfie         ; return from interrupt
;  SETUP  (runs this only once at startup)
setup           ; goto label
   ; Note! 16F84 version.
   ; Note! here we set up peripherals and port directions.
   ; this will need to be changed for different PICs.
             ; OPTION setup
   movlw b'10001000'     ;
     ;  x-------     ; 7, 0=enable, 1=disable, portb pullups
     ;  -x------     ; 6, 1=/, int edge select bit
     ;  --x-----     ; 5, timer0 source, 0=internal clock, 1=ext pin.
     ;  ---x----     ; 4, timer0 ext edge, 1=\
     ;  ----x---     ; 3, prescaler assign, 1=wdt, 0=timer0
     ;  -----x--     ; 2,1,0, timer0 prescaler rate select
     ;  ------x-     ;  000=2, 001=4, 010=8, 011=16, etc.
     ;  -------x     ;
             ; Note! We set the prescaler to the wdt, so timer0
             ; has NO prescaler and will overflow every 256
             ; instructions and make an interrupt.
   banksel OPTION_REG     ; go proper reg bank
   movwf OPTION_REG     ; load data into OPTION_REG
   banksel 0         ; back to normal bank 0
             ; PORTB pins direction setup
             ; 1=input, 0=output
   clrf PORTB       ;
   movlw b'00000000'     ; all 8 portb are outputs
   banksel TRISB       ; go proper reg bank
   movwf TRISB       ; send mask to portb
   banksel 0         ; back to normal reg bank
             ; PORTA pins direction setup
             ; 1=input, 0=output
   clrf PORTA       ;
   movlw b'00000000'     ; all 5 porta are outputs,
             ; (with 16F84 porta only has lower 5 bits)
   movwf TRISA       ; send mask to porta
             ; INTCON setup
             ; for this code example, we enable the timer0
             ; overflow interrupt.
             ; enable interrupts last
             ; interrupt setup
   movlw b'10100000'     ; GIE=on TOIE=on (timer0 overflow int)
   movwf INTCON       ; set up.
   ; Note! Now the hardware is set up we need to load the
   ; first count for one second into our 24bit bres variable.
             ; Note! This example uses 4 MHz clock, which is
             ; 1,000,000 counts per second.
             ; We require a 1 second period, so we must load
             ; 1,000,000 counts each time.
             ; 1,000,000 = 0F 42 40 (in hex)
             ; We also need to add 256 counts for the first time,
             ; so we just add 1 to the mid byte.
             ; Check mid overflow if needed.
             ; here we load the 24bit variable.
   movwf bres_hi       ; put in hi
   movlw 0x42 +1       ; get mid value (note we added 1 to it)
   movwf bres_mid       ; put in mid
   movlw 0x40       ; get lsb value
   movwf bres_lo       ; put in mid
             ; now setup is complete, we can start execution.
   goto main         ; start main program
;  MAIN  (main program loop)
main             ; goto label
   ; Note! This example uses the timer0 overflow interrupt.
   ; This will interrupt our main program every 256 instructions
   ; and do the one second timer system.
main_loop           ;
             ; Note! here you have your main program code,
             ; or calls to the main program pieces.
             ; The interrupt does all the one second timer stuff.
   ; stuff
   ; stuff
   ; stuff
   ; stuff
   goto main_loop       ; keep running the main code.
   end           ; no code after this point.
[/CODE=ASM]
andrew132
Joined Feb 2, 2017
96
Max.
Code:
; INTERRUPT VERSION
; MPLAB stuff here
; Variables here
     bres_mid       ; mid byte
     bres_lo       ; lo byte
   ENDC
; Code here
reset
int_handler         ;
             ; 24bit subtract.
             ; 24bit add.
int_exit
   swapf w_temp,f
setup           ; goto label
             ; OPTION setup
   movlw b'10001000'     ;
     ;  -------x     ;
             ; 1=input, 0=output
   clrf PORTB       ;
             ; 1=input, 0=output
   clrf PORTA       ;
             ; INTCON setup
             ; interrupt setup
main             ; goto label
main_loop           ;
   ; stuff
   ; stuff
   ; stuff
   ; stuff
[/CODE=ASM]
im new to Pic can u be more simple plz
MaxHeadRoom
Joined Jul 18, 2013
30,808
It depends on whether you want to just blink a LED or learn Assembly, using a supplied program will not gain any learned knowledge.
The sample PGM from Roman is highly commented which in itself is a teaching tool.
Go through the instructions one at a time and you will learn what he has done in what is essentially a very simple program!
Max.
andrew132
Joined Feb 2, 2017
96
Max.
i want to know how to make delay using timer0 i want to use it in subroutine
OBW0549
Joined Mar 2, 2015
3,565
Google the phrase, "how to use TMR0 on pic16f84a" and lots of good stuff comes up, including a number of tutorials on how to use the timer with assembly language.
I strongly suggest you read the PIC16F84A data sheet, especially Section 5 (pages 19 and 20) on the timer module.
andrew132
Joined Feb 2, 2017
96
Code:
BSF STATUS,RP0
BCF OPTION_REG,T0CS
BSF OPTION_REG,3
CLRF TRISB
BCF STATUS,RP0
BSF     INTCON, TMR0IE
BSF     INTCON, GIE
CLRF TMR0
BSF PORTB,1
CALL L
BCF PORTB,1
L:
BCF PORTB,0
MOVF TMR0,W
XORLW 0X255
BTFSS STATUS,Z
GOTO L
RETURN
OBW0549
Joined Mar 2, 2015
3,565
is that correct ?
I have no idea, and I'm not going to take the time to check it for you. That's your job, not mine.
Figure it out for yourself: step through the program on paper, or in your head, or in MPLAB's simulator and see if it does what you intended.
andrew132
Joined Feb 2, 2017
96
bro im new to pic and i dont have a teacher to help me so plz help me i have exam after 2 days
andrew132
Joined Feb 2, 2017
96
and i didnt use timer0 from before so i dont have any idea how to use it
andrew132
Joined Feb 2, 2017
96
So we get you through the exam, whats next?
There is a general rule here not to answer exam papers, guidance only . Not really doing you any favours.;)
Max.
if you gived me the solution in timer0 i will not take your job or your career or anything else im just a student who want help
