PIC16F84A TIMER0
Damian P
Joined Mar 23, 2020
10
Hi everyone,
I was wondering if anyone could help.
I have written a little code, essentially I'm using External RB0 interrupt, Port change RB4 interrupt and TIMER_0 interrupt.
When bit 5 of INTCON is set to 1 (Enable timer), my program jumps automatically to the ISR; skipping the while loop.
But If the bit 5 INTCON is set to 0, the program works fine and I can use my OTHER interrupts.
The code:
C:
void setup(void);
void __interrupt() inSetup(void){
 DO SOMETHING !
 return;
//Main Function
void main(void)
  setup();
  while(1){
void setup(void) {
    // Port configuration
    TRISB = 0B11111111;// Setting 'B' as input
    TRISA = 0B00000;// Setting 'A' as output
    OUTPUT_PIN1 = 0;
    OUTPUT_PIN2 = 0;
     // TIMER_0 & INTERRUPT SETUP
    INTCON = 0b10100000;
    OPTION_REG = 0b10000111; //bit 2 - bit 0 pre-scaler assignment 1:2,
Mod edit: code tags
BobTPH
Joined Jun 5, 2013
11,649
An interrupt handler must clear the interrupt flag before exiting. If it does not, it will just be called again immediately.
Bob
Damian P
Joined Mar 23, 2020
10
Hi Bob,
I've tried clearing the flag right after I set the bit 5 in INTCON, no luck; still jumps straight to ISR and for some reason stops there.
upand_at_them
Joined May 15, 2010
939
Does your compiler handle context saving/restoring for you? Also: Why are you using an ancient chip? Modern PIC's are better in EVERY way, including cost.
JohnInTX
Joined Jun 26, 2012
4,787
Hi Bob,
As @BobTPH said, you must clear timer interrupt flag INSIDE the interrupt routine then do your processing. When the interrupt routine exits, main will execute until the timer rolls over again and raises T0IF to trigger another interrupt.
When setting up, clear the interrupt flags before enabling interrupts.
You don't need a return instruction at the end of the interrupt routine. The compiler will do that for you and manage the interrupt re-enable as well.
As for writing for an old chip, you can write good code or bad code for any chip. The 'F84 will foul your plans as well as a PIC32 if you don't use it correctly. The basics are the same for either. Once you have those settled, you would be wise to consider a newer part.
Damian P
Joined Mar 23, 2020
10
if(INTCONbits.INTF){ // Test for EXTERNAL interrupt flag
OUTPUT_PIN1 = 1;//RA0
delay_traffic();
delay_traffic();
delay_traffic();
delay_traffic();
delay_traffic();
delay_traffic();
