goodness,, how incredibly sweet of you!! thank you so much ;-;I cleaned it up for you. No warnings left and added some comments to help you debug it.
Good luck!
Good luck!
noted, thank you again ^^See the note in #20 about ADCON1.
I edited it after you saw it I think.
Did the 16F84A work on the real piano or just on Proteus? How was its sound quality?DonutChan said:I had my piano program successfully work on PIC16F84A, but when i took the same program with the same wiring to another PIC(Pic16F877) on Proteus...
Ah.. all on ISIS for now. the sound quality on isis was pretty bad@DonutChan
Upon reading your recently closed thread here. I occurred to me that your opening sentence could be read two ways,
but it was definitely enhanced.. just not perfect yet@DonutChan
| Thread starter | Similar threads | Forum | Replies | Date |
| N | Help Debugging PIC16F84A Code for Dual Tank System | Homework Help | 1 | |
| D | PIC16F84A TIMER0 | Microcontrollers | 8 | |
| D | Musical note using PIC16F84A (Assembly code) | Programming & Languages | 5 | |
| J | PIC16F84A with Matrix Keypad. | Microcontrollers | 1 | |
| A | How to use TIMR0 in PIC16F84A using assembly language PLZ I need help | Microcontrollers | 44 |
