Yes, you are right. I thought about it but left the job for OP.Wouldn't it be clearer to use
gsmState = SEND_AT_CPIN_QUERY
Then the comment is hardly necessary.
And similar for all 'gsmState = x' lines.
Ha ! I did get this part.Yes, you are right. I thought about it but left the job for OP.
You didn't get the other parts ?Ha ! I did get this part.
* Project name:
C_string
* Copyright:
(c) Mikroelektronika, 2008.
* Revision History:
20080930:
- initial release;
* Description:
This program demonstrates usage of standard C string library routines.
Compile and run the code through software simulator.
* Test configuration:
MCU: PIC16F887
http://ww1.microchip.com/downloads/en/DeviceDoc/41291F.pdf
Oscillator: HS, 08.0000 MHz
Ext. Modules: -
SW: mikroC PRO for PIC
http://www.mikroe.com/mikroc/pic/
* NOTES:
- None.
char *res;
int result;
void main(){
char txt[] = "mikroElektronika";
char txt_sub[10] = "mikr";
/* memchr */
res = memchr(txt, 'e', 16);
res = memchr(txt, 'e', 5);
/* memcmp */
result = memcmp(txt, txt_sub, 16); // 111
result = memcmp(txt, txt_sub, 4); // 0
/* memcpy */
res = memcpy(txt+4, txt_sub, 4);
res = memcpy(txt+10, txt_sub, 2);
/* memmove */
res = memmove(txt+5, txt_sub, 4);
res = memmove(txt+11, txt_sub, 2);
/* memset */
memset(txt_sub+5,'a',2);
/* strcat */
txt_sub[3] = 0;
strcat(txt_sub,"_test");
/* strchr */
res = strchr(txt_sub, 't');
/* strcmp */
result = strcmp(txt,txt_sub); // 19
/* strcpy */
res = strcpy(txt, txt_sub);
/* strlen - Returns length of given (null-terminated) string */
result = strlen(txt); // 8
/* strncat */
txt[3] = 0;
txt_sub[4] = 0;
res = strncat(txt,txt_sub,8);
txt[3] = 0;
res = strncat(txt,txt_sub,2);
/* strncpy */
txt_sub[4] = 0;
res = strncpy(txt,txt_sub,8);
/* strspn */
result = strspn(txt,txt_sub); // 4
/* strcspn */
result = strcspn(txt_sub,txt); // 0
result = strcspn(txt_sub,"dxc"); // 4
result = strcspn(txt_sub,"dxk"); // 2
/* strncmp */
txt[4] = 'r';
result = strncmp(txt_sub,txt,3); // 0
result = strncmp(txt_sub,txt,6); // -114
/* strpbrk */
res = strpbrk(txt_sub,txt);
/* strrchr */
txt_sub[3] = 'k';
res = strrchr(txt_sub,'p'); // 0
res = strrchr(txt_sub,'k');
/* strstr */
txt_sub[3] = 0;
res = strstr(txt,txt_sub);
txt[2] = 'P';
res = strstr(txt_sub,txt); // 0
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
#define ON 1
#define OFF 0
#define HIGH 1
#define LOW 0
#define TRUE 1
#define FALSE 0
#define SEND_AT 0
#define SEND_AT_CPIN_QUERY 1
#define AT_COPS_QUERY 2
#define AT_CSQ_QUERY 3
// GSM module connections
sbit gsmReset at RD7_bit;
sbit gsmReset_Direction at TRISD7_bit;
// End of GSM module connections
sbit LED at RD0_bit;
char gsmBuffer[40];
char buffer1[50];
char sms[30];
char smsIndex[4];
char signalStrength[5];
unsigned char myFlags = 0;
char gsmAttempt = 0, gsmState = 0;
unsigned int gsmBufferIndex = 0, signal_strength = 0;
sbit sendSmsFlag at myFlags.B0;
//GSM Constant Strings
const char atCommand1[] = "AT\r";
const char atCommand2[] = "ATE0\r";
const char atCommand3[] = "ATE1\r";
const char atCommand4[] = "AT+IPR=9600\r";
const char atCommand5[] = "AT+CMGF=1\r";
const char atCommand6[] = "AT+CPMS=\"SM\",\"SM\",\"SM\"\r";
const char atCommand7[] = "AT+CNMI=2,1\r";
const char atCommand8[] = "AT+CMGR=";
const char atCommand9[] = "AT+CMGS=\"0000000000\"\r";
const char atCommandA[] = "AT+CMGD=1,4\r";
const char atCommandB[] = "AT+COPS?\r";
const char atCommandC[] = "AT+CPIN?\r";
const char atCommandD[] = "AT+CSQ?\r";
const char atCommandE[] = "ATH\r";
const char atResponse1[] = "\r\nOK\r\n";
const char atResponse2[] = "ERROR";
const char atResponse3[] = "+CMTI: \"SM\",";
const char atResponse4[] = "> ";
const char atResponse5[] = "RING\r\n\r\n";
const char atResponse6[] = "NO CARRIER";
const char atResponse7[] = "NO ANSWER";
const char atResponse8[] = "+CFUN: 1";
const char atResponse9[] = "+CPIN: READY";
const char atResponseA[] = "+COPS: 0";
const char atResponseB[] = "+COPS: 0,2,47201";
const char atResponseC[] = "+COPS: 0,2,47202";
const char atResponseD[] = "+CSQ: ";
const char atResponseE[] = "AT\r\n\r\nOK\r\n";
const char atResponseF[] = "AT+COPS?\r\n\r\n+COPS: 0\r\n\r\nOK\r\n";
const char atResponseG[] = "AT+COPS?\r\n\r\n+COPS: 0,2,47201\r\n\r\nOK\r\n";
const char atResponseH[] = "AT+COPS?\r\n\r\n+COPS: 0,2,47202\r\n\r\nOK\r\n";
const char atResponseI[] = "AT+CPIN?\r\n\r\nERROR\r\n";
const char atResponseJ[] = "AT+CPIN?\r\n\r\n+CPIN: READY\r\n";
const char atResponseK[] = "AT+CSQ\r\n\r\n+CSQ: ";
const char atResponseL[] = "AT+CSQ\r\n\r\n+CSQ: 99,99\r\nOK\r\n";
const char atResponseM[] = "AT+CMGF=1\r\n\r\nOK\r\n";
const char atResponseN[] = "AT+CMGD=1,4\r\n\r\nOK\r\n";
const char atResponseO[] = "ATH\r\n\r\nOK\r\n";
const char atResponseP[] = "AT+COPS?\r\n\r\n+COPS: ";
const char atResponseQ[] = "ATH\r\n\r\n";
const char atResponseR[] = "AT\r\n\r\n";
const char atResponseS[] = "AT+CPIN?\r\n\r\n";
const char msg1[] = "No Network ";
const char msg2[] = "No SIM ";
const char msg3[] = "No Network And No SIM";
const char msg4[] = "Network and SIM Ready";
const char msg5[] = "Signal Strength = ";
const char msg6[] = "Not Registered On Network";
const char msg7[] = "SIM Removed";
const char msg8[] = "OK ";
const char msg9[] = "ERROR ";
const char msgA[] = "SIM Ready ";
const char msgB[] = "Dhi Mobile ";
const char msgC[] = "Ooredoo ";
const char msgD[] = "Incoming Call";
const char msgE[] = "Call Hanged-Up";
const char sms1[] = "LED is ON";
const char sms2[] = "LED is OFF";
const char sms3[] = "Invalid Command Received";
//Function Prototypes
void DelayXSec(unsigned long int sec);
char *CopyConst2Ram(char *dest, const char *src);
void GSM_RESET();
void Extract_SMS(char *s1, char *s2);
void Get_SMS_gsmBufferIndex(char *s1, char *s2);
void Get_GSM_Time(char *s1, char *s2);
void Get_Code(char *s1, char *s2);
void GSM_Send_Const_Command(char *s1, char *s2, const char *s3, const char *s4, unsigned int *idx, char *gsmAttempt, char clr);
void GSM_Get_SMS(char *s1, char *s2, const char *s3, const char *s4, char *s5, unsigned int *idx, char *gsmAttempt, char *s6, char clr);
void Send_SMS(char *s1, char *s2, const char *s3, const char *s4, const char *s5, const char *s6, const char *s7, char *s8, unsigned int *idx, char *gsmAttempt, char clr);
void interrupt() {
if((RCIE_bit) && (RCIF_bit)) {
if(OERR_bit) {
OERR_bit = 0;
CREN_bit = 0;
CREN_bit = 1;
gsmBuffer[gsmBufferIndex++] = UART1_Read();
gsmBuffer[gsmBufferIndex] = '\0';
RCIF_bit = 0;
char *CopyConst2Ram(char *dest, const char *src){
char *d;
d = dest;
for(;*dest++ = *src++;)asm clrwdt;
return d;
void DelayXSec(unsigned long int sec) {
while(sec != 0) {
Delay_ms(1000);
asm clrwdt
--sec;
void GSM_RESET() {
asm clrwdt
gsmReset = 1;
Delay_ms(20);
gsmReset = 0;
void Extract_Signal_Strength(char *s1, char *s2) {
unsigned int i = 0;
asm clrwdt
while(*s1) {
if(*s1 == '\n')
++i;
asm clrwdt
*s1++;
if(i == 2)break;
asm clrwdt
while(*s1 != ' ') {
*s1++;
asm clrwdt
*s1++;
while(*s1 != ',') {
*s2++ = *s1++;
asm clrwdt
*s2 = '\0';
asm clrwdt
void Extract_SMS(char *s1, char *s2) {
unsigned int i = 0;
asm clrwdt
while(*s1) {
if(*s1 == '\n')
++i;
asm clrwdt
*s1++;
if(i == 2)break;
asm clrwdt
while((*s1) && (*s1 != '\r')) {
*s2++ = *s1++;
asm clrwdt
*s2 = '\0';
asm clrwdt
void Get_SMS_Index(char *s1, char *s2) {
while(*s1 != 'C') {
*s1++;
asm clrwdt
while(*s1 != 'M') {
*s1++;
asm clrwdt
while(*s1 != 'T') {
*s1++;
asm clrwdt
while(*s1 != 'I') {
*s1++;
asm clrwdt
while(*s1 != ',') {
*s1++;
asm clrwdt
*s1++;
while(*s1 != '\r') {
*s2++ = *s1++;
asm clrwdt
*s2 = '\0';
asm clrwdt
void GSM_Send_Const_Command(char *s1, char *s2, const char *s3, const char *s4, unsigned int *idx, char *gsmAttempt, char clr) {
asm clrwdt
while(strstr(s1, CopyConst2Ram(s2, s3)) == 0) {
UART1_Write_Text(CopyConst2Ram(s2, s4));
DelayXSec(2);
(*idx) = 0;
if((*gsmAttempt)++ == 2) {
//GSM_RESET();
//memset(gsmBuffer, '\0', sizeof(gsmBuffer));
(*gsmAttempt) = 0;
(*idx) = 0;
break;
if(clr)memset(gsmBuffer, '\0', sizeof(gsmBuffer));
(*gsmAttempt) = 0;
(*idx) = 0;
void GSM_Get_SMS(char *s1, char *s2, const char *s3, const char *s4, char *s5, unsigned int *idx, char *gsmAttempt, char *s6, char clr) {
asm clrwdt
CopyConst2Ram(s2, s4);
strcat(s2, s5);
strcat(s2, "\r");
UART1_Write_Text(s2);
DelayXSec(2);
if((*gsmAttempt)++ == 3) {
GSM_RESET() ;
(*gsmAttempt) = 0;
(*idx) = 0;
(*idx) = 0;
Extract_SMS(s1, s6);
asm clrwdt
void Send_SMS(char *s1, char *s2, const char *s3, const char *s4, const char *s5, const char *s6, const char *s7, char *s8, unsigned int *idx, char *gsmAttempt, char clr) {
asm clrwdt
asm clrwdt
GSM_Send_Const_Command(s1, s2, s3, s5, idx, gsmAttempt, 1);
GSM_Send_Const_Command(s1, s2, s3, s6, idx, gsmAttempt, 1);
GSM_Send_Const_Command(s1, s2, s4, s7, idx, gsmAttempt, 1);
UART1_Write_Text(s8);
Delay_ms(500);
UART1_Write(0x1A);
DelayXSec(6);
(*idx) = 0;
asm clrwdt
void main() {
OSCCON = 0x77; // 8MHz Internal Osc.
ANSEL = 0x00; // D I/O
ANSELH = 0x00; // Rest as Digital IO.
CM1CON0 = 0x07; // Disable Comparator 1.
CM2CON0 = 0x07; // Disable Comparator 2.
PORTA = 0x00; // Clear PORT A.
PORTB = 0x00; // Clear PORT B.
PORTC = 0x00; // Clear PORT C.
PORTD = 0x00; // Clear PORT D.
PORTE = 0x00; // Clear PORT E.
TRISA = 0xFF; // PORT A as Input.
TRISB = 0x00; // PORT B as Output.
TRISC = 0x38; // RC <0-2> As Output, Rest as Input
// PORTDimg = 0x2F; // PORT D Shadow, Identical to TRISD.
TRISD = 0xFF; //
TRISE = 0xFF; // PORT E as Input.
//------- Initialte ADC & LCD & UART -------------------------------------------
//ADC_Init(); // Innitiate ADC.
VCFG0_bit = 1; // Externel Vref +.
VCFG1_bit = 0; // Internal Vref - as GND.
Lcd_Init(); // Innitiate LCD.
Lcd_Cmd(_LCD_CLEAR); // Clear LCD.
Lcd_Cmd(_LCD_CURSOR_OFF);// Cursor OFF.
Delay_ms(100); // Wait to Stabilize.
UART1_Init(9600); // Initialize UART module at 9600 baud.
Delay_ms(100); // Wait for UART module to stabilize.
//------- Clear IRQ and Fire up the Timers -------------------------------------
OPTION_REG = 0x81; // No pullups, Timer 0 at Prescaler 4.
INTCON = 0; // Disable All Interrupts First.
PIE1 = 0; // Disable All Peripheral Interrupts.
PIE2 = 0; // Disable All Peripheral Interrupts.
INTCON.T0IE = 1; // Enable the Timer0 Interrupt.
INTCON.T0IF = 0; // Clear Timer 0 Register Overflow Flag.
// TMR0 = TMR0set; // Load Timer 0 with Preset.
T1CON = 0x30; // No gate, Int Tcyc/8, TMR1 Stopped.
TMR1H = TMR1L = 0; // Timer counts up to CCP value.
CCPR1 = 625; // 1usTcyc * 8 Prescale * 625 = 5msec.
CCP1CON = 0x0B; // NO Hardware PWM.
TMR1IF_bit = 0; // PIR1 reg, Clear the TMR1 Overflow IRQ.
CCP1IF_bit = 0; // Clear TMR1 IRQ flag bit.
RCIF_bit = 0; // Clear Rx Interrupt Flag .................
T1CON.TMR1ON = 1; // Start TIMER 1.
TMR1IE_bit = 1; // Enable the Timer1 overflow Interrupt.
PIE1.RCIE = 1; // Enable Rx Interrupt .................
CCP1IE_bit = 1; // Enable the CCP1 Interrupt.
INTCON.GIE = 1; // Global Interrupt Enabled.
while(1) {
asm clrwdt
switch(gsmState) {
case SEND_AT:
//Send AT and check for AT\r\n\r\n
GSM_Send_Const_Command(gsmBuffer, buffer1, atResponseR, atCommand1, &gsmBufferIndex, &gsmAttempt, 0);
DelayXSec(1);
if(strstr(gsmBuffer, CopyConst2Ram(buffer1, atResponse1))) { //OK received
LCD_Out(2,1,CopyConst2Ram(buffer1, msg8)); //Print OK on LCD
gsmState = 1; //Set state to SEND_AT_CPIN_QUERY
else if(strstr(gsmBuffer, CopyConst2Ram(buffer1, atResponse2))) { //ERROR received
LCD_Out(2,1,CopyConst2Ram(buffer1, msg9)); //Print Error on LCD
gsmState = 0; //Set state to SEND_AT
break;
else if(strstr(gsmBuffer, CopyConst2Ram(buffer1, atResponse5))) { //RING received
LCD_Out(2,1,CopyConst2Ram(buffer1, msgD)); //Print Incoming Call on LCD
//Send ATH to hang-up call and check for ATH
GSM_Send_Const_Command(gsmBuffer, buffer1, atResponseQ, atCommandE, &gsmBufferIndex, &gsmAttempt, 0);
DelayXSec(1);
if(strstr(gsmBuffer, CopyConst2Ram(buffer1, atResponseO))) { //ATH_OK received
LCD_Out(2,1,CopyConst2Ram(buffer1, msgE)); //Print Call Hanged-Up on LCD
LCD_Out(2,1,CopyConst2Ram(buffer1, msg9)); //Print ERROR on LCD
break;
gsmBufferIndex = 0; //Clear uart buffer index
gsmAttempt = 0; //Clear attempt counter
break; //break
case SEND_AT_CPIN_QUERY:
//Send AT+CPIN? and check for response AT+CPIN?\r\n\r\n
GSM_Send_Const_Command(gsmBuffer, buffer1, atResponseS, atCommandC, &gsmBufferIndex, &gsmAttempt, 0);
DelayXSec(1);
if(strstr(gsmBuffer, CopyConst2Ram(buffer1, atResponseJ))) { //OK received
LCD_Out(2,1,CopyConst2Ram(buffer1, msgA)); //SIM Ready on LCD
gsmState = 2; //Set state AT_COPS_QUERY
else if(strstr(gsmBuffer, CopyConst2Ram(buffer1, atResponseI))) { //ERROR received
LCD_Out(2,1,CopyConst2Ram(buffer1, msg7)); //Print SIM Removed on LCD
break;
DelayXSec(1);
if(strstr(gsmBuffer, CopyConst2Ram(buffer1, atResponseO))) { //ATH OK received
LCD_Out(2,1,CopyConst2Ram(buffer1, msgE)); //Print OK on LCD
break;
break; //break
case AT_COPS_QUERY:
//Send AT+COPS? and check for "AT+COPS?\r\n\r\n+COPS: "
GSM_Send_Const_Command(gsmBuffer, buffer1, atResponseP, atCommandB, &gsmBufferIndex, &gsmAttempt, 0);
DelayXSec(1);
if(strstr(gsmBuffer, CopyConst2Ram(buffer1, atResponseF))) { //"AT+COPS?\r\n\r\n+COPS: 0\r\n\r\nOK\r\n"; received
gsmState = 2; //Set state to AT_COPS_QUERY
else if(strstr(gsmBuffer, CopyConst2Ram(buffer1, atResponseG))) { //"AT+COPS?\r\n\r\n+COPS: 0,2,47201\r\n\r\nOK\r\n" received
LCD_Out(2,1,CopyConst2Ram(buffer1, msgB)); //Print "Dhi Mobile" on LCD
gsmState = 3; //Set state to AT_CSQ_QUERY
break;
else if(strstr(gsmBuffer, CopyConst2Ram(buffer1, atResponseH))) { //"AT+COPS?\r\n\r\n+COPS: 0,2,47202\r\n\r\nOK\r\n" received
LCD_Out(2,1,CopyConst2Ram(buffer1, msgC)); //Print Oordeoo on LCD
break;
DelayXSec(1);
break;
break; //break
case AT_CSQ_QUERY:
//Send AT+CSQ? and check for response AT+CSQ\r\n\r\n+CSQ:
GSM_Send_Const_Command(gsmBuffer, buffer1, atResponseK, atCommandD, &gsmBufferIndex, &gsmAttempt, 0);
DelayXSec(1);
if(strstr(gsmBuffer, CopyConst2Ram(buffer1, atResponseK))) { //AT+CSQ\r\n\r\n+CSQ: received
Extract_Signal_Strength(gsmBuffer, signalStrength); //Extract Singnal Strength
signal_strength = atoi(signalStrength); //Convert Signal Strength Ascii to integer
if(signal_strength == 99) { //Signal Strength is 99
LCD_Out(2,1,CopyConst2Ram(buffer1, msg1)); //Print No Network on LCD
else {
gsmState = 4; //Set state to next state - (not coded)
DelayXSec(1);
break;
gsmBufferIndex = 0;
gsmAttempt = 0;
break;
case 4:
break;
Configuration Registers ;
CONFIG1 :$2007 : 0x23F4
CONFIG2 :$2008 : 0x0700
Oscillator : Internal 8MHz. RA6 & RA7 as Digital I/O.
Watchdog Timer : Disabled.
Power-up Timer : Disabled.
Master Clear : Enabled.
Code Protection : Disabled.
Data Protection : Disabled.
Brown Out Reset : Enabled at 4.0V.
Int. Ext. Switch : Disabled.
Failsafe CLK : Disabled.
LVP : Disabled.
ICD : Disabled.
Flash Program Self Write: Disabled.
Experimenting on how to send AT commands via UART1 using RX and TX.
checking the response to send commands through UART to a GSM Modem vis
OPEN AT commands.
Learning process to find whether I can command the modem to send SMS to
multiple hone numbers.
The Display is a 20x4 LCD in 4 bit mode used to show various functions
// lcd module connections
// end lcd module connections
// lcd interface messages
// AT Commands with CR "\r"
const char ATC00[] = "AT\r"; // Checking Response (Just OK)
const char ATC01[] = "ATE1\r"; // Enable Echo (Just OK)
const char ATC02[] = "AT+IPR=9600\r"; // Set 9600 Baud
const char ATC03[] = "AT+CMGF=1\r"; // Change to Text mode (Just OK)
const char ATC04[] = "AT+CSQ\r"; // Read the RX strength (+CSQ: xx,xx & OK)
const char ATC05[] = "AT+COPS?\r"; // SIM Registeration (+COPS: x,x,xxxxx & OK)
const char ATC06[] = "AT+CPIN?\r"; // SIM Status (+CPIN: READY)
const char ATC07[] = "AT+CMGD=1,4\r"; // Delete All SMS (Just OK after 10 sec)
const char ATC10[] = "ATH\r"; // Hang Up Incoming
// Numbers to send SMS
// Modem Response Commands to Parse
const char ATR01[] = "\r\nOK\r\n";
const char ATR02[] = "ERROR";
const char ATR03[] = "> ";
const char ATR04[] = "RING\r\n\r\n";
const char ATR05[] = "AT+CPIN?\r\n\r\n+CPIN: READY";
const char ATR06[] = "AT+COPS?\r\n\r\n+COPS: 0";
const char ATR07[] = "AT+COPS?\r\n\r\n+COPS: 0,2,47201";
const char ATR08[] = "AT+COPS?\r\n\r\n+COPS: 0,2,47202";
const char ATR09[] = "AT\r\n\r\nOK\r\n";
const char ATR10[] = "ATH\r\n\r\nOK\r\n";
const char ATR11[] = "ATH\r\n\r\n";
//const char ATR12[] = "";
//const char ATR13[] = "";
// ******* LCD Message (ROM Storage, Saves RAM) ********************************
char String[21];//Declare array set to max size required plus 1 \
(for terminator]for copying into, 20 characters + 1 = 21. (20 for 20X4 LCD)
// Copy CONST to RAM string
char * Const2Ram(char * Rifaa, const char * Shi){
char * R;
R = Rifaa;
for(;*Rifaa++ = *Shi++;);
return R;
// Modem Status LCD Display
const char MSLDCL[] = " ";
const char MSLD01[] = "Signal :";
const char MSLD02[] = "-";
const char MSLD03[] = "dBm.";
const char MSLD04[] = "SIM :"; // AT+CMGS=\"0000000000\"\r";
const char MSLD05[] = " Ready. ";
const char MSLD06[] = "ERROR!";
const char MSLD07[] = "Network:";
const char MSLD08[] = " DhiMobile. ";
const char MSLD09[] = " Ooredoo. ";
const char MSLD10[] = "Detecting!";
const char MSLD11[] = "Registering!";
#define Send_AT 0
#define CPIN_Query 1
#define COPS_Query 2
#define CSQ_Query 3
char GSM_Buffer[40];
char buffer1[50];
char SMS[30];
char SMS_Index[4];
char SignalStrength[5];
char GSM_Attempt = 0, GSM_State = 0;
unsigned int gsmBufferIndex = 0, Signal_Strength = 0;
void DelayXSec(unsigned long int sec){
while(sec != 0){
Delay_ms(1000);
--sec;
void Extract_Signal_Strength(char *s1, char *s2){
unsigned int i = 0;
while(*s1) {
if(*s1 == '\n')
++i;
*s1++;
if(i == 2)break;
while(*s1 != ' '){
*s1++;
*s1++;
while(*s1 != ','){
*s2++ = *s1++;
*s2 = '\0';
void GSM_Send_Const_Command(char *s1, char *s2, const char *s3, \
const char *s4, unsigned int *idx, \
char *GSM_Attempt, char clr){
while(strstr(s1, Const2Ram(s2, s3)) == 0) {
UART1_Write_Text(Const2Ram(s2, s4));
DelayXSec(2);
(*idx) = 0;
if(clr)memset(GSM_Buffer, '\0', sizeof(GSM_Buffer));
(*GSM_Attempt) = 0;
(*idx) = 0;
void main(){
TRISD = 0xFF; //
while(1){
switch(GSM_State){
case Send_AT: // Send AT and check for AT\r\n\r\n
GSM_Send_Const_Command(GSM_Buffer, buffer1, ATR11, ATC00, \
&gsmBufferIndex, &GSM_Attempt, 0);
DelayXSec(1);
if(strstr(GSM_Buffer, Const2Ram(buffer1, ATR09))) { //OK received
LCD_Out(2,1,Const2Ram(buffer1, msg8)); //Print OK on LCD
GSM_State = Send_AT; //Set state to CPIN_QUERY
#define Send_AT 0
#define CSQ_Query 3
void interrupt(){
if(INTCON.T0IF){
INTCON.T0IF = 0;
// BLAAAAAAAAH:
if(CCP1IE_bit){
if(CCP1IF_bit){
CCP1IF_bit = 0;
// More BLAAAAAAH;
if(OERR_bit) {
OERR_bit = 0;
CREN_bit = 0;
CREN_bit = 1;
GSM_Buffer[gsmBufferIndex++] = UART1_Read();
GSM_Buffer[gsmBufferIndex] = '\0';
RCIF_bit = 0;
Your version is working and my version is not working ?I corrected my post...it is working...I made a typo in the while(1)
my version i.e
TRISD = 0xFF; //
while(sec != 0) {
Delay_ms(1000);
asm clrwdt
--sec;
OPTION_REG = 0x8F;
[LIST=1]
[*]switch(GSM_State){
[*] case Send_AT: // Send AT and check for AT\r\n\r\n
[*] GSM_Send_Const_Command(GSM_Buffer, buffer1, ATR11, ATC00, \
[*] &gsmBufferIndex, &GSM_Attempt, 0);
[*] DelayXSec(1);
[*] if([URL='http://www.opengroup.org/onlinepubs/009695399/functions/strstr.html']strstr[/URL](GSM_Buffer, Const2Ram(buffer1, ATR09))) { //OK received
[*] LCD_Out(2,1,Const2Ram(buffer1, msg8)); //Print OK on LCD
[*] GSM_State = Send_AT; //Set state to CPIN_QUERY
| T | RS232 to TTL custom board, no output from MAX232 | General Electronics Chat | 25 | |
| O | MAX232 for ±25V from 5V supply | General Electronics Chat | 35 | |
| T | Max232 capacitor placing issues | Microcontrollers | 11 | |
MAX232 Heating issue..! | General Electronics Chat | 23 | |
Question about serial comms between a pic and a pc using a max232 | Microcontrollers | 11 |
