Question about serial comms between a pic and a pc using a max232
hunterage2000
Joined May 2, 2010
487
Hi all, I'm trying to output a single character to Teraterm using a pic16f690 and a max232. I have used the following code to output the letter 'C'.
Code:
#include <stdio.h>
#include <stdlib.h>
#include <pic16f690.h>
#include <xc.h>
#pragma config WDTE = OFF
#pragma config PWRTE = OFF
void main()
    OSCCON = 0b01111000;    //internal 8MHz oscillator
    BAUDCTLbits.SCKP = 0;   //0 = invert data to TX pins //1 = noninvert
    BAUDCTLbits.BRG16 = 0;  //8 bit baud gen used
    BAUDCTLbits.WUE = 0;    //Receiver is operating normally
    BAUDCTLbits.ABDEN = 1;  //0 = auto baud detect disabled  //1 = enabled
    TXSTAbits.TX9 = 0;      //Selects 8 bit transmission
    TXSTAbits.TXEN = 1;     //Enables transmit
    TXSTAbits.SYNC = 0;     //Select async mode
    TXSTAbits.SENDB = 0;    //0 = sync break complete   1 = send break on next TX
    TXSTAbits.BRGH = 0;     //Low baud rate speed
    TXSTAbits.TX9D = 0;     //only for 9 bit transmission
    RCSTAbits.SPEN = 1;     //Enables serial port pins TX and RX
    RCSTAbits.RX9 = 0;      //Selects 8 bit transmission
    RCSTAbits.CREN = 1;     //Enables receiver
    while(1)
        TXREG = 'C';
        while(PIR1bits.TXIF == 0);
When I probed the input and output to the max232 I think I got what I expected. For the letter 'C', the byte is 11000010.
The attached waveform shows this. I have labelled the start and stop bits as 0* and 1*. Apologies for the order of the byte.
Looking at Teraterm, the terminal is giving garbage symbols and not 'C'.
Anyone have any experience with this?
Thanks in advance.
AlbertHall
Joined Jun 4, 2014
12,653
You haven't set the baud rate. The code sets auto baud detect but you do not go through the sequence to actually set it up.
Set SRBG to 12 decimal and ABDEN to 0.
Set teraterm for 9600 baud.
For SCKP, 0 is non-inverted and 1 is inverted but 0 is the correct value as the data is going through a MAX232 this chip inverts the data.
hunterage2000
Joined May 2, 2010
487
Hi all, sorry I didn't get back sooner just been busy with work. I have set the internal oscillator using the SCS bit. I forgot to put the SPBRH value in but now its in its kind of working I've tried different characters and this is what I'm getting:
1) The number '9' (00111001) gave 5 9's then it changed to 'N' (01001110) which I noticed is '9' shifted right 2 bits
2) The letter 'F' (01000110) gave 5 F's then stopped, restarting new connection gave all F's
3) The letter 'G' (01000111) gave a zero with a caret (^)
4) The letter 'X' (01011000) gave 5 a's then all X's
Anyone know why this is happening. The noise on the waveform is not that bad.
AlbertHall
Joined Jun 4, 2014
12,653
Add a delay between the characters so the start and stop bits are clearly distinguishable by the terminal software.
hunterage2000
Joined May 2, 2010
487
Right I see. Using a delay is giving me sensible characters on Teraterm so I think I can progress with sending measured values from the adc to it. Thanks all.
Picbuster
Joined Dec 2, 2013
1,062
Code:
#include <stdio.h>
#include <stdlib.h>
#include <xc.h>
void main()
    while(1)
        TXREG = 'C';
Thanks in advance.
Not all baud rates are possible see manual.
Always use Interrupts to collect data. Let me know if a sample program is needed.
Below is a simple example to calculate settings for baud rates but again check manual.
You are able to fiddle the 8MHz internal clock to adjust baud rate ( see manual).
Picbuster
#define _XTAL_FREQ 8000000
#define FOSC 8000000L
#define NINE 0 /* Use 9bit communication ? FALSE=8bit */
#define BAUD 4800
#define DIVIDER ((int)(FOSC/(16UL * BAUD) -1))
#define HIGH_SPEED 1
#if NINE == 1
#define NINE_BITS 0x40
#else
#define NINE_BITS 0
#endif
#if HIGH_SPEED == 1
#define SPEED 0x4
#else
#define SPEED 0
#endif
#define RX_PIN TRISB5 //pin 12
#define TX_PIN TRISB7 //pin 10
/* Serial initialization */
#define init_comms() \
RX_PIN = 1; \
TX_PIN = 1; \
SPBRG = DIVIDER; \
RCSTA = (NINE_BITS|0x90); \
TXSTA = (SPEED|NINE_BITS|0x20)
