Photodiode, I don't know how it works here.
Xenon02
Joined Feb 24, 2021
504
Hello !
I've got a problem understanding one thing.
I've got this graph
I know that the more light the photodiode takes the more current it creates. Just like the photodiode is like a current source but what happens if I cross this current U_B/R_L ?
Something like this ?
Because when I give more light it looks more like it not photodiode anymore it;s more like photovoltaic.
DickCappels
Joined Aug 21, 2008
10,661
That is exactly what’s happening -the junction becomes forward biased so the most voltage you can get is one diode drop per junction.
I have a friend who makes solar cells. One day at lunch, in answer to a question he remarked “We are in the diode business. Really big diodes.”
Irving
Joined Jan 30, 2016
5,195
Photodiodes can be used either in photoconductive or photovoltaic modes. If the diode is reversed biassed it is in photoconductive mode. Initially, when dark, the diode leakage is minimal, but as the light intensity increases the leakage current increases. This is the fastest response mode and is used for beam interruptors, IR receivers, etc. Normally its arranged so the junction never becomes forward biassed even at the highest light level.
https://en.wikipedia.org/wiki/Photodiode
Xenon02
Joined Feb 24, 2021
504
But If I make the diode make more current like in my image 6mA then it is photovoltaic ?
Xenon02
Joined Feb 24, 2021
504
Or am I wrong ?
I mean if I cross this current that is Ub/RL then I change the photodiode from photodetector to photovoltaic ? Like there in my picture Ub/RL was max 5mA so when I will have 6mA because I gave enough light to make it so I change the mode ?
Irving
Joined Jan 30, 2016
5,195
A typical photodiode wouldn't generate that much current. The open-circuit voltage of a photodiode is about 430mV and the short-circuit current at 0v maybe <200uA.
Xenon02
Joined Feb 24, 2021
504
Okey but I mean the example I gave. I want to know theoretically if I changed the mode from photodetector to photovoltaic ?
I mean here What happens if I cross the Ub/RL. Is it photovoltaic ?
Xenon02
Joined Feb 24, 2021
504
Its not how a photodiode works; there is no external current unless its zero-biassed. Maybe this series of articles will help:
https://www.allaboutcircuits.com/te...odiodes-the-nature-of-light-and-pn-junctions/
I still don't get it.
But tell me in the most simple way you can. What happens If I give enough light to get Ub/RL, and give a little bit more light than for the Ub/RL ? What happens ?
Will this happen ? Or what will happen ?
First image there is Ub/RL. So what happens if I give a little bit more light ? Like in the second one. Does it work like that ?
Xenon02
Joined Feb 24, 2021
504
I feel a little bit dumb because I feel that this is very easy but my mind can't proccess it.
Because I know how the photodetector works to the moment of Ub/RL. But I don't know what happens if (theoretically) I will cross this value like in this picture Ub/RL = 5mA but now I give more light, and what now?
Xenon02
Joined Feb 24, 2021
504
Academic.
I want to understand it. Just want to know what happens when I cross this Ub/RL that's all. The moment I have Ub/RL and when I give more light what will happen then.
Danko
Joined Nov 22, 2017
2,193
When you cross Ub/RL, current through photodiode is maximal.
When you give more light, current still equal Ub/RL. Photodiode is saturated.
Xenon02
Joined Feb 24, 2021
504
Aaaaa good to know.
Because I was thinking that maybe the diode will produce even more current because this photodiode as a photodetectore mode is working like current source.
Danko
Joined Nov 22, 2017
2,193
In this circuit battery produces voltage, RL defines maximal current, but photodiode only limits current at level, defined by light intensity.
Irving
Joined Jan 30, 2016
5,195
As has been said, there is a limit on the actual current that will be output. For a photodiode that's intended to work in reverse-biassed or zero-bias configurations that limit will be at around 1mW/cm2 or 10W/m2 which is why data sheets generally only show values up to that point. 10W/m2 is typically medium to bright indoor lighting (1000W/m2 is generally taken as the maximum irradiation from the sun overhead on a cloudless day, and is used for solar panels and other true photovoltaic cells).
You can think of a photodiode as a perfect diode in parallel with a current source and a parallel load resistor Rp, plus a series resistor Rs to the external connection. The current source is linear with respect to the light power up to a certain limit but can't go above that (there only being so many electrons in the depletion layer that can be freed). The current source biasses the diode in the forward direction. Once the diode is starts conducting the current mainly flows through it giving an output voltage of typically 0.4-0.6v; when the output is shorted the photocurrent flows externally and the voltage is near to zero. These two states are illustrated in the simulation below:
The following simulations show what happens when the diode is is nominally reverse-biassed, but with different load resistances, RL < RLmax, RL = RLmax and RL > RLmax. In the middle case the diode just remains reverse or zero-biassed at max illumination, while last shows the diode going into forward-bias at high illumination.
Xenon02
Joined Feb 24, 2021
504
So the last one even if it's reverse biased it is going into forward and it is becoming fotowoltaic ?
Even though it looks like that :
It is going from reverse bias to forward bias what does it mean ?
I can understand that more light won't produce more current. The RL give the limit.
Irving
Joined Jan 30, 2016
5,195
Once the diode starts conducting, because the load resistance doesn't allow enough current from the battery to maintain reverse bias, the photocurrent is absorbed by the diode pn junction and voltage across the diode is clamped at -0.5v approx. leaving the external current fixed at (5 - -0.5)/RL or about 110uA.
You were earlier considering the diode in photovoltaic mode behaving like a battery or voltage source, but its not, its more akin to a poor current source with a voltage clamp across it. Definitely non-linear.
Xenon02
Joined Feb 24, 2021
504
As I understand it.
Even though in your simulation the reverse bias is going into forward bias it is still photodetector and not a photovoltaic yes ?
