Photo sensitive circuit
hidiver808
Joined May 6, 2017
4
I have found circuits that create a night light where a light turns on when it gets dark. I need the opposite.
I need a circuit that will allow a light to run continuously on 9 volts until it gets dark. Then I would like it to turn the light off.
Can anyone help?
34,829
Can anyone help?
Most light sensitive circuits consist of a light dependent resistor (LDR) and a bias or load resistor.
One way to reverse the effect is to interchange the LDR and bias resistor.
Another way of reversing the effect is to add an inverting stage in the circuit as shown below:
And there is still a third method and even simpler method. Typically, a relay is being controlled by the light sensitive circuit. Simply change the connections to the relay from normally open (NO) to normally closed (NC) contacts.
hidiver808
Joined May 6, 2017
4
Thank you for the help. I was able to build the circuit and it works as described. The light turns off when it gets dark.
Next question I have is that the light is very dim. I assume the resistors are reducing the current flow? Is there a way for me to have full current running to the light?
I did change the transistor BC547 for a 2N3904 would that make a difference?
34,829
What circuit?
Please post the circuit you have built.
hidiver808
Joined May 6, 2017
4
This is the circuit I built. My battery is a 9 volt....but the output voltage to my light is less than 3 volts. As I mentioned I substituted a 2N3904 Transistor for the BC547 recommended in the schematic.
34,829
It depends on the LDR chosen. Try replacing R2 with a higher value resistor such as 10kΩ or replace it with a 10k-100kΩ variable resistor to allow you to adjust the switching threshold.
