- Joined Jan 23, 2018
- 28,133
The signal wire goes negative because the voltmeter negative is on the wrong lead. All voltages are relative to whatever reference point is used.
That would be me. Did you try it?One of the fellows up there tellling me to hook up 1k resistor to signal wire
==================================It is difficult to decipher what you have written in such a long post.
The bottom line is: WE DON'T KNOW.
Because we are not there looking over your shoulder to see what you are doing.
We don't know what power source you are using.
We don't know what you are using to measure voltage.
We cannot see how your device is connected and how you are taking a measurement that would produce a negative voltage.
Very far from it.This is reader's digest level english.
There are some important lessons in electronics to learn here.QUESTION: WHY DOES THE SIGNAL WIRE GO NEGATIVE WHEN THE LIGHT IS EMITTED? ONE MORE TIME, WHY?
This was the first time I've seen where you said the voltage being used was 2 volts. What is your power source? Is it an adjustable power supply? Can you preset the current? If we don't know what you're cooking we can't recommend a recipe.2 Volts to its positive leg and its negative leg to negative power supply. And by the way lets say it is DC, not AC. I am not using 2 Volts AC power. Make a note of it.
Not understanding why you're having so much trouble getting this point: When the transistor is seeing the LED the signal (output) is held to ground (and not going negative). While held to ground it either tells another part of the circuitry in the printer that - perhaps it means you're out of paper - or whatever circuit it was on. When the LED is blocked, the transistor goes open. Meaning there is no transmittal of power. An open signal can mean (in the case of sensing paper) the printer can go ahead with the printing operation.When the beam is blocked the signal goes OPEN. When the beam is Uninterrupted signal is held to GND.
Now that I have reread everything, I assume “to behave that way” means the way you saw it work on YouTube as described in your first post, though that was not clear before, the context being too far removed.Just want to know where the signal wire is connected to, to behave that way.
====================================================Nice try. What you have posted is an extremely terrible attempt to communicate.
You have posted almost 1000 words that add no clarity to your situation.
You may think that "looking over your shoulder" is a joke and unnecessary.
Because you cannot communicate properly, had we been there looking over your shoulder we could tell exactly what you are doing wrong in 10 seconds.
#1 - Use the proper language and terminology in order to communicate electronics concepts.
When a signal goes negative it should be indicated with a negative sign on a digital voltmeter.
We do not use the expression "go negative" when a signal is 0V with respect to the negative supply input.
The point of reference for measuring voltage in this case is the negative supply input. All voltages are described with reference to this point.
If there is no AC signal in your circuit, the voltage cannot go lower than the negative supply line. Hence there is no negative voltage.
If you connect the RED lead of your DMM (digital multi-meter) to the signal wire and the BLACK lead to the negative supply, you should read 0V.
If you then connect the BLACK lead of the DMM to the +2V supply line while leaving the RED lead on the signal wire, the DMM should show -2V.
This does not mean that the voltage at the signal wire is negative 2V. It is only negative with respect to +2V. The voltage at the signal wire is still 0V with respect to the negative supply line.
#2 - Understand the meaning of open-collector.
Do you know the meaning of open-collector? Do you understand what it means to apply a pull-up resistor to an open-collector output? This has already been pointed out to you.
Connect a 1kΩ resistor between the signal wire and the positive supply input.
No. It's not a voltage at all. It's an open. Not an open voltage it's just like taking your probe and sticking it in the air. You're not going to read any kind of voltage. Your meter may be saying it sees something but that's just an artifact of the meter and not a voltage.Floating voltage is that area of voltage that is neither belongs to the negative ( call it 0 volts) nor does it belong to positive voltage ( call it the high voltage). It is in between voltage.
Again, no. "Sig" is not supplying anything. It provides a path to ground when the beam is uninterrupted.the signal wire is supplying signal ( voltage or current),
I was coming to the same conclusion. Either he's trolling us or he just refuses to let go of his notions even though it has been thoroughly explained to him.I give up. I answer his exact question with a schematic, and he goes back to explaining the behavior, which all of us already understand and has been a explained in every possible way, with no comment on my answer. Apparently, his entire purpose is that argue with us.
Troll he be.
===============================No. It's not a voltage at all. It's an open. Not an open voltage it's just like taking your probe and sticking it in the air. You're not going to read any kind of voltage. Your meter may be saying it sees something but that's just an artifact of the meter and not a voltage.
When you apply 5V to the first of three wires (as shown in post #32 reading from left to right) and ground the middle pin the LED will emit light. When it emits light that reaches the photo transistor the transistor will conduct whatever is present on the signal wire will be held to ground. Being held to ground is an absolute - it is grounded. When you block the light the transistor no longer conducts whatever is present on the signal to ground - it is floating.
If you have a 24 volt lamp (and I'm using 24 as just an example) and on one lead you connect it to a 24 volt source and the other end of the SOURCE to ground (middle wire) the light will light up when the LED is shining on the transistor. When you block the light from the LED the 24 V lamp will go out. It thinks there's an open circuit - be it a switch or a broken wire the 24 volts goes nowhere.
In Tony's illustration when the beam is not broken the "Printer Ready" light will be lit. When you block the beam the "Printer Ready" light will go out. In that illustration it can be anything connected to the signal. When the beam strikes the transistor the transistor conducts whatever voltage and current present to ground. Be it a light, a fan, a siren or anything else, all the beam is doing is turning that transistor on or off. No light - no conduction. Light - transistor conducts whatever is present on the signal line. It's a follower setup. You can have a 9V battery hooked to a 9V fan, positive to the positive lead of the fan, the negative lead of the fan connected to "Sig" and the negative lead from the battery connected to ground then the fan will run unless you block the beam.
If you still don't understand then I'm at a loss to figure out a way to help you further without sitting side by side and building some experiments.
