Hi All,
I have been experiencing problems with my Philips Bodygroom BG2024 where it works right after a charge but once it turns off or has been switched off (sometimes accidentally whilst shaving) it won't start up again unless it's put back on the charge - and it also won't work if it stays on the charger for a day or two (the charger automatically disconnects the charge at some stage, I'm guessing causing the batteries to lose their charge). When it is running it works just fine with sufficient power, just a very short battery life if any.
I followed the Youtube video below for this shaver and managed to get to the battery, everything in the video appears to be identical to my unit including the batteries (750mAh).
I tested the voltage after taking it off the charger (it won't turn on due to low battery, indicator flashing) and each battery is at 1.312v, is this too low as I thought they should still work as low as 1.1v?
I used a razor blade to tear away the double sided tape securing the batteries to the PCB. The batteries are soldered to the PCB connectors at the bottom of the charger (near the charging pins) so I need to figure out how to desolder the batteries from the PCB (just that one side as the other side the batteries are soldered to one another and the pair can be freely removed). I would also need recommendations for replacement batteries, (NiMh? 2500mAh?) if they're compatible with the charger.
Recommendations please as to a) how to desolder the batteries and b) what batteries to replace with.
Adapter/charger info:
MODEL: HQ850
SSW-1789AU
Input 100-240V~
50/60Hz 2W
Output: 8V -... 100mA
IPX4
Many thanks in advance.
Munz
MODEL: HQ850
SSW-1789AU
Input 100-240V~
50/60Hz 2W
IPX4
Munz
