2xAAA philips hue motion replaced by PSU
thor21
Joined Sep 29, 2024
435
hello,
i already have multiple core branches running across the flat (12,24V), i wanted to get rid of the batteries powering philips hue motion sensor
1) already installed on 12V branch , 3.3V pololu brick.
2) the chatgpt advised that 3.3v it too much and it might be better to dump it to 2.7-2.8V
using the following components
Core
  • U1: MCP1700-3002 (3.0 V LDO)
  • C1 (input cap): 1 µF ceramic (X5R/X7R)
  • C2 (output cap): 1 µF ceramic
Optional safety drop
  • D1: Schottky diode (e.g. 1N5817, BAT54)
Is that a correct recommendation/ and should i proceed with that, could you advise?
Thank you!
28,507
Since really FRESH small batteries may deliver 1.65 volts initially, that is the voltage that I will pick to use. So the output oftwo fresh batteries with no load would be 3.3 volts. Then the "Phillips Hue Motion sensor" includes U1: MCP1700-3002 (3.0 V LDO) which is a regulator, it appears. So a supply of 3.3 volts should work quite well. With the connected device including that 3.0 volts regulator, why drop the supply voltage below that??
Jerry-Hat-Trick
Joined Aug 31, 2022
853
If you are not certain, consider the LM2596 DC/DC converter module, inexpensive and widely available. Up to 35V input can be dropped to anywhere between 1.25V and 30V. In your case I’d use a 12V input and adjust the output to 2.75V
28,507
If the current draw is as low as 100mA, how long will the two AA batteries last?? So MY GUESS , based on the supply battery size, is that the current draw is less.
thor21
Joined Sep 29, 2024
435
i just googled if the device is powered by 2x AAA , its better to replace with DC of 2.8-3V and it has less impact on its internals. no clue tho.
hello and that diode dump 3.3V to 3V? could you elaborate a bit how to connect it? thanks!
Connect the diode anode to the +3.3V supply. Connect the cathode to your circuit. The diode will drop about 0.6V so you get 2.7V. The cathode is the end with the silver band painted on it
28,507
Why is that small difference in voltage critical?? IS the aplied voltage ACTUALLY THAT CRITICAL??? SERIOUSLY!!!! Is the voltage THAT CRITICAL??? AND, if the voltage is critical, what is the negative result of it being either TWO TENTHS OF A VOLT HIGH, or possibly LOW???
IF there is an actual undesireable result, please tell us what that negative result is.
I am asking this question seriously!! Most battery powered devices are tolerant of deviations in the battery supply voltage, so I am wondering about the "philips hue motion sensor" . I AM NOT AT ALL FAMILIAR even with what such a device is, or what it does. So can it be explained what a philips hue motion sensor actually does and what it is??
I understand what "hue" is and means, and I understand quite well what a motion sensor is, and how they work. BUT " hue motion sensor" is a totally unknown entity to me. THus I am asking for an explanation.
thor21
Joined Sep 29, 2024
435
@MisterBill2 i dont know.
https://www.philips-hue.com/en-us/p/hue-motion-sensor/046677570972
chatgpt answer:
Why it doesn’t work the way you expect
The Philips Hue Motion Sensor is designed specifically for:
  • 2× AAA batteries (nominal ~3V total)
  • Very low, stable current draw
  • Internal circuitry optimized for battery discharge curves, not a fixed PSU
⚠ Key problems with using a 3.3V PSU
1. Voltage mismatch (subtle but important)
  • Fresh AAA batteries = ~3.2V (1.6V × 2)
  • Nominal = 3.0V
  • A PSU at 3.3V is higher than expected most of the time
    → This can stress or damage components long-term
2. No regulation/protection designed for PSU input
  • The sensor likely has minimal voltage regulation
  • It expects the natural voltage drop of batteries
  • A PSU provides constant voltage, sometimes with spikes/noise
3. Risk of damage or reduced lifespan
  • Overvoltage (even small) + continuous supply
  • Possible overheating, erratic behavior, or failure
4. Physical + electrical differences
  • Batteries provide:
    • Soft startup
    • Internal resistance (limits current spikes)
  • PSU provides:
    • Hard, immediate current → can stress circuits
✅ If you really want to do it (safer approach)
If your goal is to avoid changing batteries:
  • Use exact 3.0V regulated supply (not 3.3V)
  • Add:
    • A diode (drops ~0.2–0.7V depending on type)
    • Or a low-dropout regulator (LDO) to 3.0V
  • Ensure:
    • Clean DC (low ripple)
    • Correct polarity (obviously)
28,507
OK, now I see that the use of the word "HUE" does not relate to color sensing at all, but is strictly a word selected to use as a name. Quite interesting indeed.
