Philips steam iron just died (burned resistor)
Steplane
Joined Nov 19, 2024
a little presentation. : Stephane from France. I have been loving to repair stuff for ages but I don’t know and understand much on electronics. I have been following the thread about the Yamaha p95 (having a P120 with the exact same issue but not the same boards and components, I still haven’t had the courage to unsolder components to test them)
but yesterday my Philips steam iron GC9642 stopped working while using it. just died so after a small troubleshooting I opened it and found 2 burned resistors (3035 and 3037). I replaced them but still no life at all on my steam iron. As I feared, the burned resistors were not the reason of the failure but a consequence of something else which is not visible…
i really don’t know how to read technical schematics.
before buying the whole board I wanted to see if anybody had any issue like this one or any other idea
thanks and sorry for my not so good technical English
Alec_t
Joined Sep 17, 2013
15,156
Bonjour Stephane. Your English is excellent. Welcome to AAC!
Those two resistors are in a low-voltage (3.3V) section of the circuit and are not designed to carry more than a few mA of current. The only reason I can see for them burning up is if mains voltage somehow reached them and caused excessive current through them. If it did, then it is likely the MCU (Atmel-XMEGA IC) has been damaged too :-(.
twohats
Joined Oct 28, 2015
618
As a matter of interest, can you determine what Header 3 connects to?
If there is a problem upstream from Header 3, it's likely to kill your new board.
Good luck.............
