At least we have made one more step towards it working. Can you clarify a few points.
When you press play does the play light always come but its only sometimes it actually plays ?
When it stops playing is the stop LED or pause LED on (Or are all LEDs off.) ?
On the left hand side of the schematic for U301 pin 24 goes to two sets of contacts one labelled 0-Stop and the other counter 000. I assume the counter one is to set it to stop at a particular place on the tape. If this is the case are you sure this is not the reason for it stopping ?
I don't think the pressure solenoid should operate straight away. I think the capstan is always rotating then the tape would start to move as soon as the unit was switched on.
You could try wind and rewind to see they continued to the end of the tape or they also stopped at random.
Les.
Les.
