Phase-shift PWM simulation
Alec_t
Joined Sep 17, 2013
13,336
Below is the simulation of PSPWM running Linear Technology's own test fixture of the LTC1922-1 (found in the LTspice Power Products folder).
I'm surprised at the messy state of the output voltage across the load. Is this the best the chip can do? I understood that PSPWM involved zero-voltage switching, supposedly to minimise switching noise.
Ian0
Joined Aug 7, 2020
7,017
Looks like the error Amplifier is unstable. I would have expected another capacitor from comp to feedback.
ericgibbs
Joined Jan 29, 2010
17,173
hi eetech,
If you post your working asc file, I will try and see if that makes a difference.
Not sure what you mean, but...
I am pointing out that your sim shows a +5V out whereas mine shows around only ~+3 Vout
E
eetech00
Joined Jun 8, 2013
3,418
hi eetech,
Done
E
Sorry, that wasn't clear, I thought you were expecting the output to be 3v.
File is attached. The only thing I changed was the simulation time to match alex_t's.
Alec_t
Joined Sep 17, 2013
13,336
Thanks guys. I've also been using Trtol set to 7, 'cos that often seems to help convergence. I'll bear in mind how fiddling with it can make a big difference.
