Op-Amp RC Phase Shift Oscillator Simulation help needed
mishra87
Joined Jan 17, 2016
1,063
Hi All,
I tried to simulate RC phase shift Oscillator with copy book circuit and i was not able to generate sinusoidal wave even with permutation & combination.
I can not figure out the problem.
Could any body correct and explain why this copy book circuit not working ?
I used 3RC stage to give 180deg phase shift.
Attached is the simulation file.
38,748
Typically a lag phase-shift network, as show below, is used, not a lead network.
Note that the slew rate of the op amp your are using is too low, so its output looks like a sawtooth.
And use the UIC option for the transient simulation to help start the oscillation.
mishra87
Joined Jan 17, 2016
1,063
I tried with fastest opamp from LT Spice and still find it is not working.
I am not sure how much output voltage amplitude should be for this circuit ?
mishra87
Joined Jan 17, 2016
1,063
Your post #3 circuit simulates ok if you increase R3 to 560k or more.
Many thanks to your reply.
I changed opamp and now i used faster opamp. Yes, some how it worked.
I still do not agree with simulation results why because ?
1. R3 = 29*R5 = 29*10K = 290K (used 560K much far)
2. Calculated frequency = 6.5KHz and it is comming 22.7KHz
3. Amplitude is 1.6V peak no formula for this ?
Audioguru again
Joined Oct 21, 2019
6,826
Most older sinewave generators use a Jfet fed with rectified output signal for amplitude stabilization. Then the opamp does not saturate resulting in very low distortion. Temperature affects the output level a little.
I made a VERY amplitude-stable sinewave generator that has very low distortion by first making a digital stepped sinewave then filtering it with a switched-capacitor lowpass filter IC.
